Results 1 to 6 of 6
    May 24 2014
    Boston, MA
    VagCom Scan Woes - Data Bus Issues?
    02' B6 A4.
    So the other day I fired the car up in the morning, immediately it shut back off. I went to restart, had no problems since. Driving yesterday, just my speedometer bounced around 20mph up and down. Got home, performed the output test on the instrument cluster and speedo is fine again. Ran a scan today and it produced these faults. What do these point to? I also randomly get the steering angle sensor fault as well.
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
    Controller: 8E0 920 950 H
    Component: KOMBI+WEGFAHRS. RB4 D21
    Coding: 01200
    Shop #: WSC 40126
    VCID: 2E2FAD38F90F
    WAULC68E42A055486 AUZ6Z0A0165475
    1 Fault Found:
    01336 - Data Bus for Comfort System
    80-00 - Single-Wire Operation
    Address 08: Auto HVAC Labels: 8E0-820-043.LBL
    Controller: 8E0 820 043 G
    Component: A4 Klimaautomat 0711
    Coding: 00000
    Shop #: WSC 63351
    VCID: 253D5214ACF9
    6 Faults Found:
    01274 - Air Flow Flap Positioning Motor (V71)
    41-00 - Blocked or No Voltage
    00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
    30-10 - Open or Short to Plus - Intermittent
    01592 - Air Quality Sensor (G238)
    30-00 - Open or Short to Plus
    00474 - Control Module for Immobilizer
    49-10 - No Communications - Intermittent
    27-10 - Implausible Signal - Intermittent
    May 24 2014
    Boston, MA
    Quote Originally Posted by SilverB6Quattro View Post
    These 3 are easy to fix.
    01274 - Air Flow Flap Positioning Motor (V71) - motor that controls the recirc/fresh air flaps (behind glove box, easy to replace)
    00604 - Potentiometer Positioning Motor for Air Flow Flap (G113) - This one went away for me when replacing the V71 motor^
    01592 - Air Quality Sensor (G238) - This is located on the cabin air filter box in the area where the battery is. Not needed (in my opinion, still replaced it though), it is used when using the automatic recirc button
    Cool thanks for the tips. Hoping someone else chimes in for the others.
    Sent from my SM-G900V using Tapatalk
    Aug 26 2005
    The Comfort CAN Bus is a twisted pair of wires, and only one of the two wires is working, thus the "Single wire Operation". There are three CAN busses that connect together at the instrument cluster, Comfort, Infotiainment, and Powertrain CAN busses. The IC translates the CAN messages between the three CAN busses.
    The fault in the Comfort CAN buss needs to be located and fixed to restore normal function of the CAN buss.
    Vorsprung durch Technik
    May 24 2014
    Boston, MA
    Where would I look?
    May 24 2014
    Boston, MA
    Does anyone have the location of the wires?
    May 24 2014
    Boston, MA
    Ran another scan today and found these
