Results 1 to 8 of 8
    Oct 17 2004
    B8 Avant S-line +
    Marbella
    Avant going crazy
    Hi Guys,
    My 2011 model 2.0 TDI Avant is going crazy, sometimes it will not start, and the errors that come up on the dash are as follows; Stability program fault, Parking brake fault, headlight range control defective.
    The car either starts first thing or it wont and then the errors come up on the dash, if the car starts it drives 100% normal, no limp mode, nothing strange, also no errors appear when driving, they only come on start up.
    I went to see a fiend of mine to see it with vagcom, and this is the result, we're lost as we can't figure it out, we tried looking for the ECU relay, which is mentioned online for other models as 109, but we couldn't find it anywhere. Does anyone know where it might be?
    Any help is highly appreciated.
    Sunday,13,March,2016,16:48:30:63648
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 15.7.4.1 (x64)
    Data version: 20160216
    www.Ross-Tech.com
    VIN: WAUZZZ8K3BA****** License Plate: *******
    Mileage: 66020km-41022mi Repair Order:
    Chassis Type: 8K (8T0)
    Scan: 01 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 62 72
    VIN: WAUZZZ8K3BA064437 Mileage: 66020km-41022miles
    01-Engine -- Status: Malfunction 1010
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    55-Headlight Range -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (J623-CAGA) Labels: 03L-906-019-CAG.clb
    Part No SW: 03L 906 022 NN HW: 03L 906 019 AL
    Component: R4 2,0L EDC H29 9096
    Revision: 25H29---
    Coding: 12194012232403080000
    Shop #: WSC 00150 219 87778
    ASAM Dataset: EV_ECM20TDI03L906022NN A02011
    ROD: EV_ECM20TDI03L906019AL.rod
    VCID: 7EF3D950E10FD5CE0C-802A
    3 Faults Found:
    4695 - Function Restriction due to Faults in Other Modules
    U1113 00 [032] - -
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 65078 km
    Date: 2016.02.14
    Time: 19:06:52
    4698 - Function Restriction due to Faults in Other Modules
    U1113 00 [032] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 65078 km
    Date: 2016.02.14
    Time: 19:06:52
    4699 - Function Restriction due to Faults in Other Modules
    U1113 00 [032] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 65078 km
    Date: 2016.02.14
    Time: 19:06:52
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
    Part No SW: 8K0 907 379 BF HW: 8K0 907 379 BF
    Component: ESP8 front H04 0030
    Revision: -------- Serial number: --------------
    Coding: 160504
    Shop #: WSC 06335 000 00000
    VCID: 7EF3D950E90FD5CE0C-802A
    2 Faults Found:
    00473 - Control Module for Elect. Park/Hand Brake (J540)
    013 - Check DTC Memory
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 5
    Mileage: 65837 km
    Time Indication: 0
    Date: 2016.03.12
    Time: 19:33:10
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x0782
    Hex Value: 0x002E
    Hex Value: 0x0295
    Hex Value: 0x00FF
    01314 - Engine Control Module
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 6
    Fault Frequency: 7
    Reset counter: 5
    Mileage: 65837 km
    Time Indication: 0
    Date: 2016.03.12
    Time: 19:33:52
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x0782
    Hex Value: 0x0027
    Hex Value: 0xB995
    Hex Value: 0x00FF
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 CP HW: 8K0 907 064 CP
    Component: BCM2 2.0 H04 0430
    Revision: 00002001
    Coding: 032200
    VCID: 000FA7A893FBA33E7E-8054
    Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
    Component: FBSAUDIB8 IDG H50 0071
    Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
    Component: J764 ELV MLB H37 0042
    1 Fault Found:
    01330 - Central Control Module for Central Convenience (J393)
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 45
    Mileage: 65837 km
    Time Indication: 0
    Date: 2016.03.12
    Time: 19:32:36
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8T1 820 043 AH HW: 8T1 820 043 AH
    Component: KLIMA 1 ZONE H08 0180
    Revision: A1000000 Serial number: 01111020101298
    Coding: 34200000
    VCID: 77FDCC74C635E4864F-8022
    1 Fault Found:
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 45
    Mileage: 65837 km
    Time Indication: 0
    Date: 2016.03.12
    Time: 19:32:31
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
    Component: BCM1 1.0 H30 0392
    Revision: 10030001 Serial number: 00000000819782
    Coding: 260050914034AF010001000300001D0D0F1C07080601010100 0000
    VCID: 3C771358BF9307DE62-8068
    Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 071010 H06 0070
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
    Component: RLS H04 0003
    Coding: 025028
    Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
    Component: E1 - LDS H08 0090
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 45
    Mileage: 65837 km
    Time Indication: 0
    Date: 2016.03.12
    Time: 19:43:00
    Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
    Part No SW: 8K0 919 475 R HW: 8K0 919 475 A
    Component: PARKHILFE 8K H06 0070
    Revision: 11001001 Serial number: 50901028501120
    Coding: 100203
    VCID: 489F7F88FB4B5B7EF6-801C
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 45
    Mileage: 65837 km
    Time Indication: 0
    Date: 2016.03.12
    Time: 19:32:36
    Freeze Frame:
    Temperature: 21.0°C
    Address 15: Airbags (J234) Labels: 8K0-959-655.clb
    Part No SW: 8K0 959 655 J HW: 8K0 959 655 J
    Component: AirbagVW-AU10 H41 0610
    Serial number: 003GKD0L76AA
    Coding: 30343435363030303030554A304C384B3053
    ASAM Dataset: EV_AirbaECUVWAUDI010 003010
    ROD: EV_AirbaECUVWAUDI010_AU48.rod
    VCID: 44876BB8CF637F1E1A-8010
    Crash sensor for side airbag; driver side:
    Serial number: 6334MSME580561356
    Crash sensor for side airbag; front passenger side:
    Serial number: 6344MSME58042E6CP
    Crash sensor for side airbag; rear; driver side:
    Serial number: 6352QSME17714626B
    Crash sensor for side airbag; rear; passenger side:
    Serial number: 6362QSME407442245
    Crash sensor for front airbag; driver side:
    Serial number: 63732SME48743930.
    Crash sensor for front airbag; front passenger side:
    Serial number: 63832SME7B743A3CE
    No fault code found.
    Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
    Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
    Component: Lenks.Modul H17 0014
    Revision: -------- Serial number: 90372JJ800002
    Coding: 000017
    VCID: 3D711E5CA4890ED655-8068
    Component: E221 - MFL H02 0010
    Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
    Part No SW: 8K0 920 930 N HW: 8K0 920 930 N
    Component: KOMBIINSTR. H25 0258
    Revision: 00000000 Serial number: EJC32WEAA
    Coding: 0F04100002000008000000
    VCID: 387F0F488BAB2BFE86-806C
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 45
    Mileage: 65837 km
    Time Indication: 0
    Date: 2016.03.12
    Time: 19:32:37
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8T0 907 468 AB HW: 8T0 907 468 H
    Component: GW-BEM 5CAN H06 0117
    Revision: GB800053 Serial number: 5300G109238004
    Coding: 00CF07
    VCID: 0109A2AC98F1AA3671-8054
    Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
    Component: J367-BDM H07 0140
    Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
    Component: J532_DCDCStab H05 0006
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 45
    Mileage: 65837 km
    Time Indication: 0
    Date: 2016.03.12
    Time: 19:32:37
    Freeze Frame:
    Bin. Bits: 10111
    Voltage: 11.70 V
    Count: 6
    Bin. Bits: 10000
    Time: 25.40 s
    01312 - Powertrain Data Bus
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 53
    Reset counter: 45
    Mileage: 65837 km
    Time Indication: 0
    Date: 2016.03.12
    Time: 19:32:39
    Freeze Frame:
    Bin. Bits: 10000
    Voltage: 11.90 V
    Count: 7
    Bin. Bits: 10000
    Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
    Part No SW: 8K0 959 793 M HW: 8K0 959 793 M
    Component: TSG FA H12 0357
    Revision: Serial number: 0000011456115
    Coding: 011C02204100410001
    VCID: 4A9B4580E547A96EE0-801E
    Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0135966900
    Coding: 0100062020B904408120023680000000
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 45
    Mileage: 65837 km
    Time Indication: 0
    Date: 2016.03.12
    Time: 19:32:35
    Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
    Part No SW: 8K0 959 792 M HW: 8K0 959 792 M
    Component: TSG BF H12 0357
    Revision: Serial number: 0000011458736
    VCID: 49997A8CE041A276E9-801C
    Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
    Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
    Component: EPB Audi B8 H09 0100
    Revision: 00000003 Serial number: 00000000759455
    Shop #: WSC 00000 000 00000
    VCID: 34673B7897C3CF9EAA-8060
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 2
    Reset counter: 45
    Mileage: 65837 km
    Time Indication: 0
    Date: 2016.03.12
    Time: 19:32:36
    Freeze Frame:
    Voltage: 11.80 V
    Count: 64
    Speed: 0.0 km/h
    Hex Value: 0x0270
    Hex Value: 0x0001
    Hex Value: 0x0101
    Address 55: Headlight Range Labels: 8K0-907-357.clb
    Part No: 8K5 907 357 B
    Component: Dynamische LWR H02 0010
    Revision: 00000001 Serial number:
    Coding: 0000004
    VCID: 39790A4C70A132F679-806C
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 45
    Mileage: 65837 km
    Time Indication: 0
    Date: 2016.03.12
    Time: 19:32:32
    Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
    Part No SW: 8T1 035 186 P HW: 8T1 035 186 P
    Component: Concert3 H07 0350
    Revision: 00000011 Serial number: AUZ5Z6J1475895
    Coding: 0500048004020500015B070000
    VCID: 44876BB8C7637F1E1A-8010
    Subsystem 1 - Part No SW: 8T0 919 603 F HW: 8T0 919 603 F
    Component: Display
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 45
    Mileage: 65837 km
    Time Indication: 0
    Date: 2016.03.12
    Time: 19:32:37
    Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
    Part No SW: 8K0 959 795 F HW: 8K0 959 795 F
    Component: TSG HL H11 0357
    Revision: Serial number: 0000109201912
    Coding: 010C02204000210001
    VCID: 458176BCCC5946160D-8010
    Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
    Component: TSG HR H11 0357
    Revision: Serial number: 0000109202023
    End-------------------------(Elapsed Time: 02:29)--------------------------
    '11 A4 []S-line Avant TDI
    Gone but not forgotten:
    Oct 17 2004
    B8 Avant S-line +
    Marbella
    I forgot to add when the 3 errors appear on the dash if I leave the key in the engine fan goes nuts, and sometimes even continues when I pull the key out, it will only stop after I close/open the car again with the keyfob.
    Jul 16 2008
    Finland
    You need to remove the codes and see which ones come back, but my guess would be that this is a handbrake issue.
    ______________________________________
    2013 A4 B8.5 Avant 1.8tfsi quattro, Ibis White. Mods: 8x18 OZ Leggera HLT for winter, OEM RS4 9x19 for summer, OEM trunk organizer rails, Underseat storage bins, S4 pedals, LED interior lights, H&R Sport, tint.
    Oct 17 2004
    B8 Avant S-line +
    Marbella
    Hi TDIaholic, most of them come back.
    Oct 17 2004
    B8 Avant S-line +
    Marbella
    OK so update, although nothing great.
    I substituted the relay for the ECU with one from the boot, and no joy, and I changed the Terminal 15 voltage
    supply relay for a new one as there was none to substitute with.
    What did happen though is I could start 3/4 times, and then I got an error only just the ESP one, and it still let me start the car, the handbrake and lights were gone for another 3 attempts after, and then they came back and it wont start again. The errors only appear on the dash when I try to start it they do not appear when it runs.
    Another thing I noticed is when I unplug the negative on the battery and wait a bit, when reconnecting it then starts OK again a couple of times, and then it's back to square 1.
    Seeing as the car is half apart, I did notice that the relay for the glow plugs and engine current makes a lot of clicks before when I start and it doesn't, in the notes it says it's for this:
    A - Automatic glow period
    control unit -J179-
    → Note
    A - Engine components
    current supply relay
    -J757- → Note → Note
    If the glow plug light goes out then I can start, if it stays on it wont start and the other errors also come up.
    I'm lost, I guess I'm just looking way to deep into it as now everything seems to do something.
    Established Member Two Rings X Y Z's Avatar
    Mar 20 2013
    SM610, AE86, FJ60
    Portland, Oregon
    I'm really curious what your battery voltage is. Have you ever replaced the battery? I ask because I've seen quite a few b8 posts with similar/strange electrical issues like yours, and a lot of them seemed to be battery related.
    Oct 17 2004
    B8 Avant S-line +
    Marbella
    I don't remember off the top of my head, I will check again later on and post it up.
    I had a new battery in there for 2 days and it made no difference, although I'm now wondering if it could be that the new battery wasn't recognised by the system due to me not changing the BEM code?
    Oct 17 2004
    B8 Avant S-line +
    Marbella
    I get 12.41 on the battery when just opening the boot and the key isn't in the ignition. I'm not knowledgeable on batteries, so forgive me if doesn't make any sense or is useless, but when the car has the error on the dash I get 12.03, and if there is no error on the dash I get 12.26. And with the car on, it goes up to 14.6x gradually as it sits there idling (maybe more but shut it off as the smell of a Diesel idling doesn't give such a healthy feeling).
