I've been chasing a few codes since January of this year and have been able to get rid of a few of them with a couple parts but cannot seem to get rid of the P310b code and the P0300/0303 codes!?
Here's my Vag scan from January 2016 when the Random/Multiple Cylinder Misfire Detected codes started:
3 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 - - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 209510 km
Time Indication: 0
Freeze Frame:
RPM: 1325 /min
Load: 45.9 %
Speed: 0.0 km/h
Temperature: 30.0°C
Temperature: 18.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.097 V
000771 - Cylinder 3
P0303 - 008 - Misfire Detected - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 209510 km
Time Indication: 0
Freeze Frame:
RPM: 1313 /min
Load: 44.7 %
Speed: 0.0 km/h
Temperature: 31.0°C
Temperature: 18.0°C
Voltage: 14.097 V
004688 - Fuel Level too Low
P1250 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 209510 km
Time Indication: 0
Freeze Frame:
RPM: 1283 /min
Load: 45.1 %
Speed: 0.0 km/h
Temperature: 31.0°C
Temperature: 18.0°C
Voltage: 14.224 V
Readiness: 0000 0000
I replaced the coil packs with the red tops from ECS Tuning and Autolite XP Iridium/Spark Plugs as well as did a carbon cleaning on the valves 3 weeks ago to try to fix the rough idle the car is experiencing. The car has so much more power and is much more responsive now but is hard to start after it has been sitting overnight. During the carbon cleaning I did remove the HPFP and checked the cam follower and noticed only minor wear so I did not replace it (my car is stock). Before I replaced the coil packs/plugs I swapped out coils/plugs 2 and 3 but the error continued to stay on Cylinder 3.
I noticed on my last 2 fuel fill ups that my gauge only showed 3/4 of a full tank so I am wondering if my P310B code is due to a failing LPFP or the LPFP controller? I replaced the LPFP sensor on the HPFP about 9 months ago as well as the PCV to the latest revision around the same time.
Here's the scan from today:
3 Faults Found:
012555 - Low Pressure Fuel regulation
P310B - 004 - Fuel Pressure Outside Specification - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 219563 km
Time Indication: 0
Freeze Frame:
RPM: 1353 /min
Load: 49.4 %
Speed: 0.0 km/h
Temperature: 27.0°C
Temperature: 24.0°C
Voltage: 14.224 V
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 219563 km
Time Indication: 0
Freeze Frame:
RPM: 1275 /min
Load: 51.4 %
Speed: 0.0 km/h
Temperature: 28.0°C
Temperature: 23.0°C
Voltage: 14.224 V
000771 - Cylinder 3
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 219563 km
Time Indication: 0
Freeze Frame:
RPM: 1208 /min
Load: 45.1 %
Speed: 0.0 km/h
Temperature: 36.0°C
Temperature: 22.0°C
Voltage: 13.970 V
Readiness: 0000 0001
Any help is greatly appreciated so I can get this thing fixed and running right! Thanks.
