Results 1 to 13 of 13
    Jul 30 2010
    Los Angeles, CA, 90094
    AWE Track Exhaust. Drone is Unbearable with DSG. Need Help with Fix!
    Hey everyone,
    So I recently just got the AWE Track Edition Exhaust, and it sounds amazing. However, When i'm between 2-3k rpm, the drone in the car is just unbearable. My girlfriend is complaining that it hurts her ears, and I honestly don't blame her.
    Anyone know what I can do to alleviate this problem? I'm currently using stock downpipes, and I've heard that getting a resonated downpipe might get rid of the drone. Anyone have any experience with this?
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    The Resonated DPs help for sure. I have zero drone
    Jul 30 2010
    Quote Originally Posted by GRUMPY-S4 View Post
    Which downpipe did you end up going with?
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Yeah, I think your only real option is to try the resonated downpipes to see if it helps, or try to switch it out for a touring version. The resonated downpipes are going to do quite a bit to kill the drone on a DSG model.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Veteran Member Three Rings Jv218's Avatar
    Jun 10 2015
    15 S4, 2012 civic
    Boston
    Go with res DP and if that doesn't work dyno Matt and u believe disabling the sound generator works too. If you just installed the track it does drone more then when it finally breaks in
    15 Ibis white, Dsg, P+, magma interior, F1 35% pinnacle tint, ECS RS4 grill, AWE Track 90mm tip, 19x9.5inch HRE FF01, ECS Carbon Intake
    Veteran Member Four Rings zcspec's Avatar
    Aug 10 2015
    Need VAG-COM work, IM me
    Orange County
    Resonated DPs are going to cost you an arm and a leg, plus installation if you don't have the means to install them yourself. An alternative would be to keep your current setup and install two small resonators, one on each pipe after the central muffler. The affect is essentially the same as running resonated DPs without the substantial cost.
    Mar 21 2015
    Turn your soundaktor off too, that will help.
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    This. Pull the fuse if you haven't already. After that, the resonated DP's AWE offers are your best bet since they are cheaper than converting it to the Touring. If you are the original owner you can get the discounted DP's for up to a year after your catback only exhaust purchase.
    Senior Member Two Rings mavz's Avatar
    Apr 06 2015
    not sure how much resonated down pipes are gonna help... but as others have said that's kinda all you can do if you want to keep the track. The disabling of the soundakor definitely helps a tiny bit. I will say this tho, even the touring drones.
    Gone: 2013 Estoril S4
    APR - AWE - Vorsteiner - Continental - ECS - Akebono - JHM
    Veteran Member Four Rings s4matty's Avatar
    Aug 15 2015
    2 feet
    Niagara canada
    Does the track exhaust use a x pipe?
    I know placing a x pipe as close to the engine as possible will really help with drone.It also will produce more power close to the engine also by speeding up the airflow..
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by s4matty View Post
    It does, but it is a ways down past the "downpipes" (I say that because what we call the downpipes are after the cats). The track is the same basic layout as the touring, but the rear resonators are replaced with strait pipes.
    So, it's basically exhaust manifolds-->cats-->either stock, resonated, or non-resonated downpipes-->then either:
    -Touring: x-pipe, central muffler, two resonators where the mufflers are
    -Track: x-pipe, central muffler, strait pipes
    Aug 15 2015
    2 feet
    Niagara canada
    Yes it has a x...Just looked it up.You still have stock dp's I see.Loose the baby resonators,it will be louder yes but really help with the drone..I have built a few custom exhausts for dsg s4s and those little resonators up front really create a drone with aftermarket exhausts.
    Aug 15 2015
    2 feet
    Niagara canada
    Thank you for the information! I build my own,so not sure what some of the company's offer.
