Results 1 to 9 of 9
    Veteran Member Three Rings quattro_silver's Avatar
    Jun 18 2008
    Chicago, IL
    Intake Manifold - How clean does it need to be when changing gaskets?
    I'm changing my gaskets out on my Intake Manifold (car is at 210,000 mi). I stuffed the ports w rags and have been using brake cleaner to get the grime off. As you
    can see in the pics it's coming off, but there's still some grime.
    Does this look clean enough to install the gasket on the drivers side? Or does it need to be cleaned more?
    I'm afraid to use anything abrasive.. I bought a polishing kit that fits on a drill from autozone (medium grit) that a guy said to use at the store.. but it was leaving slight swirl marks.
    APR
    Vogtland Coilovers
    BBS CH black/lip
    Piggies/Neuspeed G2
    E-Codes + DDM 55w 6k
    SRP pedals
    Hawk HPS + Adams slotted
    Kicker CompVT
    Veteran Member Three Rings cinimod25461's Avatar
    Dec 04 2013
    CA
    You should be good as long as all the surfaces are smooth so that the intake manifold seals to the heads properly.
    Jun 18 2008
    Chicago, IL
    APR
    Vogtland Coilovers
    BBS CH black/lip
    Piggies/Neuspeed G2
    SRP pedals
    Kicker CompVT
    Aug 31 2014
    2002 stage 3 a6 6MT 2004 cavalier
    Charlotte/Roanoke
    ^^+1 above. No "bumps" by touch and your set
    Jun 18 2008
    Chicago, IL
    I accidently snapped a mangold bolt when trying to torque it to 10Nms. Any idea what I should do now?
    I have no idea how to get it out. It's the 2nd from bottom on the drivers side.
    APR
    Vogtland Coilovers
    BBS CH black/lip
    Piggies/Neuspeed G2
    SRP pedals
    Kicker CompVT
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    Possibly grab it with a vice grip and loosen that way if there is some material to grab on to.
    Past (in order): Hibiscus Red B5 A4 ,2003 Audi RS6, B6 s4, UrQuattro, Urs4, Nogaro sport B5 S4 avant, Silver stg 3 B5 s4, 2010 A6 Avant prestige
    Present: Casablance White stg 3 B5 S4 avant, 2002 Audi S6
    Senior Member Three Rings Nizmo's Avatar
    Oct 09 2015
    Boston
    Metal drill bit smaller than the threads.
    Then chase the threads with the correct thread tap, or carefully with a new IM bolt.
    Nov 02 2014
    06 9-3 Aero 2.8T, 96 Miata
    Winchester, VA
    Broken bolts are tricky, but not hard.
    Get an extractor.
    Drill bolt stud, hammer extractor in, and remove stud.
    Be careful, drill slow.
    Jun 18 2008
    Chicago, IL
    Thanks for the help. I buttoned everything back up after changing the aux water pump and
    she started right up. I may wait to get that bolt replaced, and may pay an experienced mechanic
    to switch it out.
    The issue is I always have to use an adapter on my torque wrench to concert down to 1/4" and
    since it was wobbly it didn't register correctly at 10Nms. It allowed over torque.
    Time to buy a nice torque wrench..
    APR
    Vogtland Coilovers
    BBS CH black/lip
    Piggies/Neuspeed G2
    SRP pedals
    Kicker CompVT
