Results 1 to 8 of 8
    Oct 20 2015
    Dublin, Ireland
    Shes Arrived!! now time to do some maintenance. help needed :)
    Hi again,
    My 2003 B6 Auto 1.8T quattro has finally arrived.
    But now I need to do preventative maintenance.
    I was wondering if there is a list of "must do" things to this engine/gearbox.
    It has a service history but its all in Japanese and Im not sure what has been done and when. (my Japanese is a little rusty)
    So if any of you can direct me in the direction of a list or links of whats one should do when they first get their B6. (I have used the search button but nothing comes up)
    Senior Member Three Rings B6ayfour's Avatar
    Jun 21 2015
    2014 S4 6MT, 1989 535i5
    LI, NY
    id say all of the obvious maintenance like oil change, spark plugs and such to start. Only thing out of the ordinary that i consider a must do is the coil packs because b6 coil packs are garbage. definitely go with a good 2.0t coil pack.
    Oct 20 2015
    Dublin, Ireland
    Cheers thanks,
    I will deffo be doing the usual service type things.
    I thought I read somewhere that DV valves and some oils/vacuum lines need looking at.
    Im sure there was a thread of things to do.???
    Veteran Member Four Rings jpulll's Avatar
    Jun 19 2014
    Ohio
    Quote Originally Posted by Oisin View Post
    Cheers thanks,
    look up engine strengthening-a4darkness. you'll be set with that thread. I would recommend the 034 PCV kit instead of going OEM.
    Senior Member Three Rings Arnie91's Avatar
    Oct 28 2015
    London
    Oil Filter Change, Check the Timing Belt, Rocker Cover Gasket, Check for Injector leaks, Check engine mounts not leaking fluid
    Apr 07 2011
    This should keep you busy for a while. Click
    Feb 01 2016
    UK
    Check the plenum chamber and clear out the gunk?
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    Pics or it didn't happen
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
