Results 1 to 11 of 11
    Established Member Two Rings rtk8892's Avatar
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    Locked out of my s4!
    Hey so I have the b6 s4... I just changed the battery in my key fob and now I'm locked out of the car. I only have one key to make things worse. All four doors are locked and not only does the remote not work, but sticking The key in the door doesn't work either. Anyone know how to fix this?
    Veteran Member Three Rings [a]bek.'s Avatar
    Mar 14 2013
    Should be a way to program the key of turn it and hold the key to open the windows
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    I've tried everything I can think of, I even sprayed a bunch of wd40 in the lock cylinder
    - - - Updated - - -
    There must be a sequence or something I haven't tried
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    if you turn and hold the key in the lock cylinder , can it lower the windows ?
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    No it won't do that either
    Veteran Member Three Rings JayDog747's Avatar
    Mar 10 2010
    2007 S4,2015 Silverado,2023 WRX
    WI
    HELLO! If he can turn the key to roll the windows down, he can unlock the fucking door. I know it's Sunday morning but Jesus. Oh hey, did you try rolling down the window with a hammer?
    Keep working the key lock. Just be patient and don't force it. It may finally break free. Or, if the key lock works for the trunk and snake past the back seat...
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    I have the vis carbon fiber trunk and the key doesn't work in it :/ I guess I'll keep trying the door with the key
    Mar 10 2010
    WI
    Well that's a pooper.
    Veteran Member Three Rings jr1415us's Avatar
    Mar 08 2011
    Chicago IL
    any towing company can open the door.
    2013 Arctic White Allroad Premium Plus
    RIP 04 S4 Avant 2012-2017
    Mar 10 2010
    WI
    Try pressing both the lock and unlock buttons together twice.
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    Quote Originally Posted by jr1415us View Post
    Sounds like this is the best route at this point. A tow truck company should have a lockout kit to get the door open. Or you can play with a long metal coat hanger to pull the door handle on the inside to open the door.
    After they get the doors open then stick the key in the ignition, turn the ignition on, push the unlock/lock buttons a few times, turn the ignition off, take the key out, and push the unlock button on the key a few times to make sure that they have rescyronized.
    Get you driver's door lock mechanism replaced too. Hopefully before your new key battery dies or else you will have this problem again.
