Results 1 to 9 of 9
    Jun 16 2013
    SF, CA
    Brake Booster Hose?
    Hey all,
    I recently did my timing belt and motor mounts, took a couple days to do it and one time the jack accidentally lowered the engine really low and i think broke this hose. What's the name of the hose? Anyone know the part number? I can't find it on alldatadiy, and my brakes don't work :( It kind of looks like I should just be able to re-insert it into the fitting, but it doesn't go in.
    Thanks,
    John
    Jun 16 2013
    SF, CA
    I found this one specifically listed for A4 B7: https://www.ecstuning.com/ES437394/?...t7AaArYD8P8HAQ
    Crazy $120 lol. Do you know if the one you listed will fit/work?
    Veteran Member Three Rings swaggerwagon's Avatar
    Sep 28 2012
    NC
    Quote Originally Posted by profase View Post
    DOn't quote me but I'm pretty sure that won't fit. I've broken that assembly twice now in the past year. It's expensive to replace.
    B8.5 3.0T/ B5.5 1.8T
    Senior Member Three Rings nan07's Avatar
    Jul 07 2011
    Frisco, Texas
    To be honest I was pretty hammered when I posted that, and no, it doesn't look like it will fit.
    Feb 24 2004
    Minneapolis
    I'm the kinda guy who'd JB Weld that. It's already screwed up, you can't break it!
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Jun 16 2013
    SF, CA
    Yeah I ended up expoying it at the same time I ordered a new one. The expoy-fix has been working for a week, but I'll probably just swap it out for the new one for the piece of mind.
    Oct 24 2015
    Perth, WA
    $35 bucks cannot go wrong and better than a bandaid solution.
    My respray thread
    Jul 07 2011
    Frisco, Texas
    Quote Originally Posted by Okedokey View Post
    i must have been really hammered cause i just re read what i posted and its for a mk4 tdi engine
