Results 1 to 4 of 4
    Established Member Two Rings sleuthnorange's Avatar
    Nov 15 2005
    Ford Explorer
    Waukesha, WI
    034 Motorsport 6 Speed Trans Mount Install Help
    I purchased an 034 motorsport trans mount for my 6 speed and I am slightly confused with the assembly of the mount (mostly the center bolt). I think I have it on correctly but if anyone with experience installing this on their own car could weigh-in on that it would be helpful.
    The way I currently have it assembled is:
    1. The center allen bolt first passes through the provided spacer (that has the 034 engraved on it),
    2. Then it passes through the 034 mount itself,
    3. Next it passes through the triangle-shaped transmission bracket,
    4. Then through a washer
    5. Then through the locknut.
    I thought, maybe for a second, that the spacer was supposed go right after the triangle-shaped transmission bracket but then the bolt would be running into the body of the transmission itself once you would bolt up the triangle-shaped to the transmission.
    Sep 17 2005
    Fremont, California
    Here's an explanation with picture courtesy of the awesome folks at JHM. Hope that helps!
    Veteran Member Three Rings DarrenOman's Avatar
    Nov 03 2014
    2009 Gray A3
    California
    When i installed mine, i had to support the tranny and unbolt the old mount and also the main tranny support bracket. Then remove the old mount from the main support bracket.
    Here comes the tricky bid, you have to dismantle the new mount to fit it into the small gap of the main support and reassebly the mount before re-installing the main support onto the car.
    Its tight can can be done in an hour or two. Good luck
    Sent from my SM-G920F using Tapatalk
    Nov 15 2005
    Ford Explorer
    Waukesha, WI
    Thanks for the responses! I got it installed correctly. I am doing a 6 speed manual swap at the moment so the install wasn't really any extra work. I just wanted to get it right the first time so I didn't have to struggle with it later.
