2003 A4 1.8T 5-speed lots of maintenance
Up for sale is my 2003 Audi A4 1.8T Quattro 5-speed. It currently has a little over 176k on the clock, but is my current daily driver so that will go up. Clutch/Trans only have ~60k on them. Dark metallic blue over tan leather. I have done a lot of maintenance to it in my time of ownership thinking it would be my daily for the next 5 years, but I am switching gears and getting back into the 5cyl game. This thing is great on gas, and awesome in the snow. It is a great daily driver that isn?t mind numbingly boring and if you want, it?s in perfect shape to put a tune on it or move up to a larger turbo (it currently has the stock tune). A/C blows cold, sunroof works fine, heat works great, and cruise control is functional. Aftermarket head unit, bluetooth capable, usb plug in, sub in truck (although disconnected, not my thing). Suspect aftermarket speakers but have never popped the door panels off to verify.
Comes on 16? OEM Avus wheels with Hankook snow tires that only have ~5k miles on them.
Note: ski racks, bike rack, and wind fairing to NOT come with the car, but the bars may be part of the deal if you choose.
I have a few misc extra parts that we can work into the deal if you so choose as well.
Recent maintenance:
Timing belt, water pump, camshaft seals, upgraded 710N valve, inner + outer tie rods, both front wheel bearings.
Pipercross reusable/washable air filter, air cabin filter with activated charcoal.
Camshaft and crank position sensors, miscellaneous vacuum check valves.
ECS Tuning 2.0T coil pack upgrade with adapter, OEM ignition wiring harness with protector/sheath, fuel harness pigtails.
Full PCV system overhaul: 034 silicone PCV system with billet PCV valve, pressure regulator, suction/jet pump.
Glove box hinge fixed, seat back + lumbar support fixed.
New windshield, OEM all weather floor mats.
Current needs:
Some spots of the paint?s clear coat isn?t 100%.
PO burnt part of the driver?s seat bolster.
Right rear bulb needs replacing at time of pictures being taken, will take care of that before time of sale.
That?s about it. I?ve done my best to make sure the car is up to full capacity.
Shoot me a message if you want to know more or to come see it, thanks for looking.
PANJO SAYS MY PHOTOS ARE TOO LARGE, SO HERE'S MY CL AD: http://denver.craigslist.org/cto/5488705821.html
List Date: 3/13/2016
For more info, click here to view the original listing: 2003 A4 1.8T 5-speed lots of maintenance
This item is no longer available.
