Results 1 to 13 of 13
Thread: Battery Level
    Veteran Member Four Rings dennisA4's Avatar
    Jan 13 2006
    Houston
    Battery Level
    I enabled the hidden menu with Carista, then I followed the instructions in this video (with the exception of using different buttons to access the menu since I have a b8.5 MMI) and I can't get the battery level to show up.
    I'm looking in Car Systems, the same place as the Oil Level.
    Anyone with a B8.5 get it to work? Am I looking in the right place?
    https://www.youtube.com/watch?v=zMTtglRmrww
    2014 A4 Prestige Quattro Tip
    Glacier White | S-Line Interior | Sport Package | Window Shades | 35% FormulaOne Tint | V1 Hardwired
    S4 Aluminum Pedals | 19x9.5 Avante Garde M590 | KW V1 Coilovers | AWE Dual Exhaust | ECS Luft-Technik Intake | Unitronic Stage 1+
    Established Member Two Rings Canary2323's Avatar
    Jun 18 2015
    Westerly RI
    Look on YouTube, I found directions on there.
    Sent from my Nexus 6 using Tapatalk
    Sep 28 2015
    WA
    Quote Originally Posted by Canary2323 View Post
    Can you provide a link? Thera are so many videos, which one is the right one.
    Just keep flying.
    Mar 21 2015
    No battery meter in 8.5
    Jan 13 2006
    Houston
    WTF! I got a couple codes that after searching might mean my battery is on the way out. Wanted to see what the status was.
    02256 and 03041.
    Dammit.
    Aug 03 2013
    Renton, wa
    I enabled it in mine. I used vag-com though
    '22 X3M - Stock...for now
    '14 S4 P+ DSG 034 Stage 2+ ECU/TCU 57.7/190, AWE Touring, MercRacing, AWE S-Flo, Stoptech STR-60 - Gone but not forgotten
    '14 A4 S-Line Sport Package 6MT - Totaled
    '12 Tiguan SEL 4MO.
    '03 Mustang Cobra "Stock"
    Mar 21 2015
    Quote Originally Posted by VeeDubbinJetta View Post
    Everything i've read says no in the 8.5. Lets see a pic. Maybe it's different from A to S.
    Aug 03 2013
    Renton, wa
    I'll grab a pic in a bit, I just realized that you have mmi, I do not. Maybe that's the reason why?
    '12 Tiguan SEL 4MO.
    Jun 18 2015
    Westerly RI
    No sure if b8. 5 can do it but if Google mmi battery audi a4, it pops right up
    Veteran Member Four Rings Mr.Audi's Avatar
    Feb 26 2008
    none
    BALTIMORE
    What's the button combo to access it?
    Sent from ....
    B8.5 S-line prestige
    #fourringarmy
    Jan 13 2006
    Houston
    Quote Originally Posted by Mr.Audi View Post
    Sent from ....
    You have to enable hidden menu first, via vag-com or barista.
    Then go into the Car menu and then hold down the two buttons CAR and MENU for a few seconds.
    Feb 26 2008
    none
    BALTIMORE
    Quote Originally Posted by dennisA4 View Post
    So I have carista , I'll enable it and
    I'll give it a shot
    I didn't know exactly what combo to use
    Is it true you have to do some sort of reboot?
    Sent from ....
    #fourringarmy
    Jan 13 2006
    Houston
    I'll give it a shot
    Sent from ....
    See the video in my first post.
