Results 1 to 9 of 9
    Senior Member Two Rings a4ced's Avatar
    Mar 07 2016
    Lehigh Valley PA
    Brakes Constantly Squeaking
    Hey guys I just bought an 06 A4 2.0T Quattro a little while ago and replaced the brakes because they were squealing. Now I've had a new set of rotors and pads front and back for the past month and still at low speed stops it squeals horribly. Is there anyway to stop this?
    Sent from my SM-G928P using Audizine mobile app
    Veteran Member Four Rings Biged243's Avatar
    Mar 27 2013
    Vr6 gti
    Metro Detroit Michigan
    What do you have? Can take apart clean everything lube everything and rebed the pads to the rotors.
    What ever makes sense go with the opposite and you got it
    Veteran Member Four Rings dalmation53's Avatar
    Aug 20 2013
    Miami
    Op I was having the same problem unfortunately for this to stop you need to take off the pads and put brake quite on the back of the pads. this is the only fix i had to do that last week and it finally stopped. go to advance auto parts ,oreilys or autozone carry it and sometimes walmart.
    Ivan
    Feb 24 2004
    Minneapolis
    ^^This^^ Did you use brake quiet on the back of the pads?
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    May 31 2015
    2017 Mazda CX-5 Touring
    Twin Cities, MN
    What pads did you replace with? I put on some Akebono ceramics and always got that low speed squeal. After two months i finally picked up some OEM semi metallics at the dealership (same price, but came with new clips and caliper bolts which was nice) and my problems were gone as well as much better stopping power than the ceramics (i didn't think they would be THAT much worse, but they were). As these guys say, you can try the brake quiet as the cheaper first solution, but if the problem doesn't go away, you may be on the line for a better set of pads.
    '06 A4 Avant 2.0TQM S-Line Brilliant Red- | JHM High Flow Cat | Bosal Center exhaust | 034 Snub, motor, & trans mounts | 034 Spherical Front Sway End Links | 034 Street Density Control Arms | Meyle HD tie rods | ST coilovers | 750# Hyperco rear springs | Bilstein B8 rear shocks | S4 rear brake swap | Mk2 TT Turbines w/Pilot Sport AS3 | Blizzaks for snow
    -Plans: 155k and going...
    Veteran Member Three Rings midnight407's Avatar
    Oct 21 2011
    Brilliant Black B7, '06 STi borrowed/stolen from the roommate
    Northcenter/Ravenswood Chicago
    is this different from the creaking at low speed braking?
    midnight407
    Chicago, IL
    Jun 27 2011
    I had akebonos and they were completely silent aside from rattling in the carriers in the front over potholes.
    Squealing sounds like something wasn't lubed or was installed incorrectly.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Mar 07 2016
    Lehigh Valley PA
    Mine were replaced with OEM as well and no it is definitely speaking sounds like the pads are going. I didn't use brake quiet though I could go look for that and try it.
    Veteran Member Three Rings allstock's Avatar
    Mar 19 2014
    greater sub of Chicago
    OEM...so the pads and rotors are Audi brand?
