Results 1 to 7 of 7
    Mar 09 2016
    PA
    Audi A3 Sporadic Rough Idle
    Hello to all. I am new here. I had my 2006 Audi A3 2.0T FSI FWD DSG for 5 years now.
    I was wondering if anyone had the same problem as me? The mechanic said it was common something to do with the turbo.
    After my car is all warmed up, and driven for lets say about 20 miles my engine will idle kind of rough when in neutral. It drives okay. No misfires or CEL. This only happens when my car is warmed up and in neutral. When it's on drive, it does not idle rough. When I start it on the morning, it idles perfectly.
    It's driving me nuts that I had my valve cover gasket replaced. I tightened every hose that I can. Still it's there. Sporadic.
    Does anyone else had the same problem? Is this inherent of the FSI engine? Common?
    Any help is appreciated.
    Thanks.
    My setup:
    K&N Typhoon CAI
    Full Turbo Back Exhaust
    New Coilpacks and Denso Spark Plugs
    BSH Stage 1 PCV
    Unitronic Stage 1+
    Senior Member Two Rings Dad A3's Avatar
    Dec 24 2011
    2018 Audi S4, 2012 Audi A3, 2006 Audi A3, 2017 Touareg, 86 VFR 750
    Bergen Co. NJ USA
    What's the mileage, and has the carbon been cleaned from the intake? Had the same problem with mine at about 90K carbon clean fixed it.
    Mar 09 2016
    PA
    Mileage is 126K
    I will clean the intake with seafoam (unless there are any other suggestions) and replace the N80 valve.
    Will give you a feedback. Thanks for the reply.
    Mar 09 2016
    PA
    Update:
    Replaced the N80 Valve
    Did cleaning with Seafoam
    Rough idle has gone a bit but it's still there. Again when it's in NEUTRAL or PARK. When on DRIVE it's fine no rough idle. Pulls ok and drives ok.
    ANY ADVICE on what to look at next? I was thinking to have it decarbonized manually by taking out the intake manifold...
    Thanks.
    Veteran Member Four Rings MurkyRivers_A4's Avatar
    Dec 17 2009
    Tools, boxes of random car parts, 55 gal drum of used oil
    Kentucky
    Quote Originally Posted by A3 Driver View Post
    Update:
    Thanks.
    Pretty sure that's what Dad A3 meant when he asked if you had the carbon cleaning done. Seafoam will not do the trick and you will have to do it manually by removing the intake manifold. Remember to buy yourself a manifold install kit if you are planning to remove it. I have heard that the injector grommets get ruined when pulling the manifold.
    2015 Daytona Grey Audi S4 | DSG
    2013 Ibis White Audi A4 | Tip
    2006 Brilliant Black A4 Titanium | 6 speed
    Mar 09 2016
    PA
    Quote Originally Posted by MurkyRivers_A4 View Post
    Duly noted. Thank you. I will have it done soon.
    Senior Member Two Rings 0mn1's Avatar
    Jan 02 2016
    Connecticut
    Check Coils, Plugs, clean MAP, and you can use BG cleaner for FP and inectors.
