I thought I would share this since I have not heard of any similar issues on the forum. I share this story both to disseminate information about potential coolant issues (perhaps there is a trend?) and also to illustrate the work involved if you break down while tuned. I don't think the tune caused this mechanical failure, and my SA at Audi agreed.
I was using cruise control on the interstate, doing about 73-75 mph, when I received a dash warning that my coolant level was low - shut engine off and check coolant. The engine had not experienced any significant load for the last 30 minutes, all highway miles. I pulled onto the shoulder immediately and saw a steady stream of pink coolant running out! The coolant bottle was nearly empty. Oh boy. Mind you, I had an APR tune on the vehicle... so I couldn't simply have it towed to the dealer unless I wanted a nice TD1! The vehicle was towed to the local tuning shop (35 miles away, $185), de-tuned, and then towed to the Audi dealer (another 20 miles away). This ordeal took about 4 hours. Audi found that the clamp on the upper front radiator hose lost spring tension and required replacement. Awful odd. 24k miles on the car.
The experience was not a pleasant one and is making me reconsider having the car re-tuned any time soon. This is the second time I needed the tune removed in the last 2 months for the dealer to work on it. Other appt was for an oil temp sensor, both front wheel hub bearings, and a rear strut..... Now that is assuming you care about TD1. I do care, given how many warranty repairs have been performed in the short amount of time I have owned this vehicle, and seemingly none are related to the tune.
