Results 1 to 3 of 3
    Aug 19 2013
    minnesota
    Drivers side roof weather stripping.
    Should I use rtv or something to glue it down?uploadfromtaptalk1457819216533.jpguploadfromtaptalk1457819239598.jpg
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    Veteran Member Four Rings agentsmith988's Avatar
    Fry Sauce, UT
    I had it in the rear on mine. I pulled it up a little to clean the surface up before throwing some JB Weld in there. It's been holding up fine for a year now.
    - Steve
    NKAWTG
    8V S3 Prestige | Sepang Exclusive Edition | APR Stage I HT | APR Carbon Intake | CTS Res Delete | H&R RSB 25mm | EMD 10mm/17.5mm Spacers | HomeLink Retro | Euro Aspherical Wing Mirrors | OsirUSA O-Shift EX Paddles
    Aug 19 2013
    minnesota
    Quote Originally Posted by agentsmith988 View Post
    J-B Weld will last longer than we will, what if I want to remove it for some crazy reason in the future? I'll probably use RTV or something.
