This is not the first time that it has happened; I'm seeing very tiny metal flakes when removing the oil filter during oil changes, and tiny metallic particles in the oil when draining. As I spread the pleats on the oil filter, I see flakes of almost bronze/silver metal. I'm starting to thing this is the rod & main bearings breaking down. As far as driving style I generally stay at 3k rpm when driving and sometimes give it some gas. I'm very curious if anyone else is seeing this during their oil changes. For now I don't hear any weird grinding noises in the engine and it sounds generally healthy.
I'm wondering what the quickest procedure is to drop the oil pan and R&R the rod bearings while the engine is in the car, until I have time to pull the engine and check out the mains.
A list of things I have already purchased, rod bolts, rod bearings, high temp sealant. Is there anything else I need? I've done 1.8t engines and not sure if the 2.0t come with thrust washers or not.
