Results 1 to 15 of 15
    Feb 09 2016
    Brisbane
    Exclamation Yet..ANOTHER!!!! Misfire question!?!?
    Ok, so straight up, i know its beem asked many many time before but i believe every case is differen.
    Basics: changed out coil pack to r8, ngk plugs gapped to 0.028 or whatevwe it os, new air filter bg44k and bg carbon inake clean...still a miss!
    The engine is a cndnc and the car is a4 q avant.
    The mis is between 2k and 3k rpm under "mild" load, around half to 3/4 throttle. Maybe 1-3 audibly noticeable misfire within the range.
    The previous had removed the the two left and right rear mufflers so could this be a back pressure issue as this is same range the boost comes ones on? Or could it be something more?
    Cheers in advance and hello from aus :)
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    If you've changed everything you listed under basics, then I would say possibly a blown head gasket. As soon as boost comes on it gets herky jerky and misfires cause it's lifting the head or drinking coolant.
    Will
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    you know its missing because what ? cel , your logging , or your best guess ?
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Feb 09 2016
    Brisbane
    No cel and no longing as yet because i can seen to get the software to install on the laptop.
    I know because i can hear and feel usually 2-3 "pops" or slight backfires. To me it feels like it could be running rich.
    It doesnt get to "herky jerky" when boost comes on, its just abit hesitant with the possible misfire and then everythings sweet.
    Established Member Two Rings nickskeeta's Avatar
    Nov 30 2014
    Hollister, Ca
    What gas are you running?
    My EPC light came on a couple weeks ago for a misfire under heavy 2nd gear load. It shut off as soon as I restarted my car. Searched online and noticed multiple people claiming bad fuel is a common problem for misfires on the B8 S4. I aways filled up with Arco (BP) 91 previously because of convenience and decided to fill it up with Shell V-Power 91 instead and the car runs noticeable smoother and have yet to throw a code since
    @nickskeeta
    2011 S4 6MT Meteor Gray Pearl
    2018 Silverado 6.2 LTZ
    Feb 09 2016
    Brisbane
    I was also running BP 98 ron and just put a tank of V-Power so i will see if there is any improvement.
    Thanks for your input.
    Veteran Member Three Rings dizzlesizzle's Avatar
    Nov 19 2011
    Rhode Island
    I only use shell 93 nitro and runs perfect. i haven't even changed my plugs yet at 61K
    --2010 S4, Premium+, Black, 6MT, NAV, B&O, Park Assist, 19" AV-M310 ET35, DTM Style Carbon Fiber Front Lip, VAG, ADS "Lite", ROC-EURO CAI, 5000K HIDs
    Feb 09 2016
    Brisbane
    Problem sorted! New MAF on the way
    Senior Member Three Rings Mat@1975's Avatar
    Jun 14 2015
    FRANCE
    Quote Originally Posted by jdell88 View Post
    Hello
    MAF ??
    Our S4 don't have MAF....
    BR
    Mat
    S4 B8.5 AVANT | S-Tronic | Full ADS | Sport Diff | Glacier White
    MRC Stage 2 Tune | MRC TCU Tune | AMS/Alpha Cooler| AWE + AFE filter intake with airbox hole
    KW HAS Springs | H&R Sway bar F&R | Custom 14 mm Front and (13 R / 16 L) mm Rear Spacers | CR-15 Strut Brace
    OEM Rotors | Michelin PSS 255/35/19
    Q5 calipers | Goodridge SS Lines | 2-pieces Girodisc Rotors Front & Rear
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by Mat@1975 View Post
    Hello
    MAF ??
    BR
    Mat
    LOL
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Feb 09 2016
    Brisbane
    Sent from my SM-G925I using Tapatalk
    Jun 14 2015
    FRANCE
    OK, i realized that you have an A4, not a S4. Maybe you did not post in the good section...
    Which engine ? it's certainly not a 3.0L TFSI of the S4 since the engine is not MAF based but MAP based.
    By the way, MaF are a weak part in VW engines.
    Hope this will slve your issue.
    BR
    Mat
    Feb 09 2016
    Brisbane
    Thanks mat!
    Im not sure which this is in to be completely honest. Kind of new to forums and audis.
    Its a 2.0 tfsi cdnc in a b8 avant quattro.
    Feb 09 2016
    Brisbane
    But yes, disconnected and its running fine so just waiting on the part.
    Now i have esp and e brake lights so need to change the codes with a VAG or something if i read correctly elsewhere??
    Nov 10 2014
    Apex, NC
    Thanks mat!
    oh here you go http://www.audizine.com/forum/forumdisplay.php/97-B8-A4
    Present:
