Results 1 to 10 of 10
    Aug 06 2014
    Somewhere
    dropped sewing needle in gearbox
    Hello guys,as i mentioned on the topic my kids dropped 2 sewing needles in to my gearshift and it caused me to couldnt change the gears.my car goes on R gear however i cant go on D.my car sounds like i am at N.any ideas ? Also is there anyway to those needles go inside to the gearbox ?
    Aug 06 2014
    Somewhere
    While my gear is at D my car sounds like N however at R it correctly goes back without anyproblem.
    Veteran Member Four Rings mithril's Avatar
    Jul 23 2010
    Port Moody, BC
    No, the needles can't make it into the gearbox. You just need to take off the gear shift knob and the cover plate to fish out the needles.
    Current: 2012 Q7 Prestige 3.0T
    Former: 2008 FSI V8 Touareg, Galpagos Grey Metallic on Sienna interior… self-immolated due to low pressure fuel leak on exhaust manifold
    Former: 2002 S6, Silver on Silver Pearl w/ Alcantara insert.... stolen, used in a targeted gang murder and given a Viking funeral
    Former: 2000 A6 4.2L... killed by a distracted driver
    Mar 21 2015
    Why are your kids playing with sewing needles?
    Veteran Member Four Rings R490's Avatar
    Mar 04 2014
    2024 Ford Bronco
    Northern Virginia
    ^ That
    2003 Audi S6 Avant
    2005 Audi S4 6MT SOLD, 2001.5 S4 6MT SOLD, 2001.5 S4 Tip SOLD, '00 A6 2.7t Quattro 6mt SOLD, '97 A4 2.8 Quattro 5mt SOLD
    Aug 06 2014
    Somewhere
    Hello guys,thanks for replies.I am tailor and thats why there were needles at my car.I forgot i put some needles over there after work and when i reminded,it was too late.I asked my kids where are the needles and they said "sorry we dropped them there".Today i openned the gear shift knob and i didnt see any needles overthere.i have a question.There is a little gap between the plastic and the panel as i circled at the picture.There is the only way to go for needles.Is it possible to needles to go to cogwheels from there and block me to change gear correctly ?
    Sep 11 2009
    NE
    No because there is no physical connection between the selector and gearbox. Gearbox is electrically, not mechanically, commanded by control module, which in turn reacts to where you move the lever by means of sensors/switches. These needles must have wedged themselves somewhere in the works of selector.
    Aug 06 2014
    Somewhere
    So probably its a coincidence my car doesnt work.
    Sep 11 2009
    NE
    I don't think it is a coincidence. Needles probably shorted electrical contacts inside selector box or somehow locked it mechanically, but they cannot get inside of actual transmission, that's for sure.
    Aug 06 2014
    Somewhere
    When i change the gear it showes the correct gear on the cluster and also correct light turns on on the gear shift knob.Thats why i dont think it can be a selector problem.I sent the car to the mech and i will see the results.
