Results 1 to 9 of 9
Thread: Bad shocks?
    Established Member Two Rings 604bking's Avatar
    Feb 26 2015
    Bad shocks?
    A mechanic told me my rear shocks are bad and needs replacing. He lifted the car and told me the rear wheels weren't supposed to budge easily when hand-pushed from underneath. He then showed me an A4 on the next lift and indeed those wheels barely moved at all.
    Is it really time to change shocks? The car is a 2014 with ~18k miles, and H&R springs.
    2014 Audi S4 | Phantom Black | Technik | Sport Diff | Black Optics | Magma Red | Carbon | S-Tronic | RS Grille | Rho Plate | H&R Springs | H&R Spacers | 20x10 Vossen CV3 Matte Graphite....All show, no go
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    I wonder if the springs blew the stock struts, pretty common on other cars I've had. After market springs would blow struts after a week.
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Could happen if springs are a higher spring rate, kind of quick though.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Veteran Member Three Rings dizzlesizzle's Avatar
    Nov 19 2011
    Rhode Island
    what he said above...you probably blew your struts with those springs.
    --2010 S4, Premium+, Black, 6MT, NAV, B&O, Park Assist, 19" AV-M310 ET35, DTM Style Carbon Fiber Front Lip, VAG, ADS "Lite", ROC-EURO CAI, 5000K HIDs
    Veteran Member Three Rings JayDog747's Avatar
    Mar 10 2010
    2007 S4,2015 Silverado,2023 WRX
    WI
    Sure as shit that's what it was. Looks like you're getting some Koni's.
    Nov 12 2015
    Here
    Quote Originally Posted by JayDog747 View Post
    Sure as shit that's what it was. Looks like you're getting some Bilsteins.
    Fixed.
    Mein ist grau
    Mar 10 2010
    WI
    Those are fine too. That's what I'm running on. Just make sure it's the sport version(b8).
    Feb 26 2015
    Thanks guys, good to know.
    But what happens if I don't replace them?
    Jul 05 2014
    Houston
    You just "float on" brother
