Originally Posted by
Zba
It's tight down there but you may be able to lever one side of the clamp (like you are compressing only one side) by prying on it with the engine or something hard to lever on. Spray some brake clean on it to make it slippery and you should be able to rotate that clamp. Obviously this all depends on the room available.
Should I be worried about breaking the hard coolant line if I leverage one side and try to wiggle it out?
As you can see in the pic I can only get the pliers on 1 of the 2 "prongs" that loosen the clamp. I would imagine if I can bend the clamp on 1 of the prongs I can slide it off I just want to make sure I won't damage the hard line. I've spent several hours trying to get the clamp off. What do you think?
With the above being said I started the steps to remove the manifold (since I have to get this done this weekend) and I was confused of one step in the write-up I'm following.
http://www.audiworld.com/tech/eng69.shtml
There is, however, another larger black plastic or nylon vacuum connection at the back (firewall end) of the manifold fitted with a black nylon collar that releases when pressure is applied simultaneously to the opposed free sides of the collar.
What vacuum connection are they referring to? I see a plastic hose (which I removed) and 2 hard lines with collars (below the hose I'm holding). Do those 2 hard lines below the hose I'm holding need to be disconnected?
