Results 1 to 35 of 35
    Established Member Two Rings cdh9400t's Avatar
    Feb 06 2014
    Ohio
    Soft brake pedal feel
    I have noticed that the brake pedal has been feeling softer lately. But I do switch between this and a f250. I did all new pads and rotors since I was due, and I ran all new brake fluid. The car stops great and will kick abs if you push it too hard, but it's just so soft like nothing is there. Is there anything that can help this?
    Aug 01 2014
    Ohio
    maybe vacuum pump going bad?
    Feb 16 2015
    Stainless braided lines?
    2005.5 Dolphin Grey A4 Avant 2.0T Tip / Premium / Lighting / Cold Weather / Sport
    RAI K0R-GT / JHM K04 Tune / 034 HFC -> B7 S4 CB/ ST Coilovers / Hyperco 8" 750 Lb / 034 RSB / 18Z / 15% Tint / S-Line Paddle MFSW / 034 St M and T Mounts / GEN II RNSE
    Feb 06 2014
    Ohio
    How would a bad vacuum pump cause this? Wouldn't they be hard to push if that were the case? Never delt with this so I really don't know. I have looked at stainless lines, never really thought they would make much difference. I was kind of curious about metal guides instead of the weird rubber ones.
    Oct 24 2015
    Perth, WA
    Water/air in the brake fluid? Brake fluid replaced at all in the past?
    My respray thread
    Feb 06 2014
    Ohio
    Yea just did. With all new pads and rotors
    Veteran Member Four Rings Denio24's Avatar
    Jan 23 2013
    Chicago
    What kind of bleeding procedure did you do? When I barely press my brake pedal i can start to already feel it lightly grab. I don't have to press it much more for some good stopping power. If you require more pedal travel to get a good stopping distance there is probably air in the master cylinder or in the lines.
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Feb 06 2014
    Ohio
    Started with a power bleeder to remove all old fluid from resiviour and lines. Than did the old fashion way of pump and bleed. Didn't change anything. But at least my fluid is new.
    Jan 23 2013
    Chicago
    I did a pressure bleed @15psi. Sometimes hitting the caliper with a plastic hammer can free some air from the piston walls. Any chance you let the master cylinder reservoir go empty?
    Nov 25 2011
    2018 F80 M3 ZCP, 2007 RS4
    What pads did you go with? Also are is there more travel than before or are the brakes engaging but just feel mushy?
    Feb 06 2014
    Ohio
    No resiviour never went below min. I did because red stuff pads. They are very grabby. But yes peddle is mushy. Stiff as can be without car running. But mushy with it running.
    Veteran Member Three Rings JayDog747's Avatar
    Mar 10 2010
    2007 S4,2015 Silverado,2023 WRX
    WI
    You may have to bleed the brakes again. Stick with pumping the pedal. Stainless steel lines will help with firming up the pedal but stay away from the metal guides. I have about 10k left on my front pads and they are starting to knock. I'm going back to the rubber ones this weekend. You may need to take it in and have it checked for a vacuum leak. Maybe you need a hose or connector replaced.
    Mar 24 2013
    Oakdale, CT
    I would start with stainless lines. They make a big difference over old rubber lines.
    -Adam
    Feb 06 2014
    Ohio
    Well maybe I will get a new set of rubber guides since mine do have a small amount of play to them. They are cheap enough. And get a set of stainless lines. Any thoughts on ecs lines, or are Goodrich lines the way to go.
    Feb 06 2014
    Ohio
    Sorry goodridge.
    Mar 24 2013
    Oakdale, CT
    I have Goodridge lines and have no complaints. No experience with the ECS lines. I would go with whatever you can get cheapest. They are functionally equivalent.
    -Adam
    Veteran Member Four Rings jerseybrian's Avatar
    Jul 15 2011
    2008 Audi A4 2.0T Quattro QG 6spd
    Boynton Beach, FL
    I would install SS lines and the Tyrol Sport Brake Caliper Stiffening kit.
    REVO 2+ | VAST Meth | RAI HFC and 3" DP | Milltek S4 Exhaust | Autotech HPFP | 145bar PRV | JHM STS | BFI knob | 034 SD MM | ECS RA4 LWFW | ACT RS4 HDSS | QTP Cutout | Forge DV | APR Snub | Deval RS Front | Votexx 3pc wing | OEM Euro Bi-Xenons | Bilstein HD Shocks & ECS sleeves | Eibachs | RS4 RSB | S4 F&R Brakes | ECS S4 Slotted | Hawk HPS | ECS SS lines | FK LED Tails | CF Dipped Diffuser | Innovate LC1 | IE Billet | THULE | PODI
    Mar 10 2010
    WI
    Quote Originally Posted by jerseybrian View Post
    As the brake pad wears down, the stiffening kit will start to knock. Which is why I'm going back to the rubber boots this weekend.
    Jul 15 2011
    Boynton Beach, FL
    Quote Originally Posted by JayDog747 View Post
    Didn't someone find some C-clips that eliminated that gap to make it a tighter fit?
    Mar 10 2010
    WI
    Yep! Still does it.
    Jul 15 2011
    Boynton Beach, FL
    Yep! Still does it.
    hmm, what about the thicker bushing option Ive read about?
    Mar 10 2010
    WI
    Sorry 'bout the thread jack OP.
    I'm not aware of the thicker bushing option but the problem is metal against metal. The ECS kit has a rubber O-ring inside the metal sleeve that may help prevent it but I'm not going to find out.
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    Bleed the air out again until it feels stiff. Might take more than once or twice.
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Feb 06 2014
    Ohio
    It's had over 2qts of fluid bled between it and the clutch I really don't think there is still air in it.
    Jun 27 2011
    Why didn't you use the pressure bleeder for the new fluid? That seems odd.
    A bubble could have gotten stuck in the abs module causing the mushiness.
    Don't slap aftermarket parts on just yet. This sounds like an underlying issue I would solve first.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Feb 06 2014
    Ohio
    I don't have a pressure bleeder. Never have had any issues with a vac bleeder before.. Already put pads and rotors on it because they needed replaced. Had very little pad left. I'm windering if I ended up with bad/old fluid. And the only reason I say that is because the new fluid I got from summit looked like honey. Didn't think anything of it at the time. Just got a new bottle from a local parts store and it's crystal clear. Just a thought.
    Jun 27 2011
    Quote Originally Posted by cdh9400t View Post
    You said this in post 8. So did you or did you not use a pressure bleeder??
    Most fluids are tinted yellow so you can see them better I believe.
    -CP
    2017 Q7 3.0t
    Feb 06 2014
    Ohio
    I never said I have a pressure bleeder. I said power bleeder. It's a vacuum bleeder that attaches to the calipers and pulls fluid out. Runs off an air compressor. Made by matco
    Jun 27 2011
    I've always heard the terms power bleeder and pressure bleeder used interchangeably. My bad.
    So wait did you vacuum it dry then out new fluid in then? I'm confused.
    -CP
    2017 Q7 3.0t
    Mar 24 2013
    Oakdale, CT
    All pressure bleeders are power bleeders, but not all power bleeders are pressure bleeders.
    -Adam
    Jun 27 2011
    I think a more apt description would be vacuum bleeder then. #pedantics
    -CP
    2017 Q7 3.0t
    Jan 23 2013
    Chicago
    That definitely clarifies things. I've vacuum bled before and I do not like that method, as there is always some air left in the system. I like to pressure bleed because that ensures it starts by purging air from the master cylinder first, rather than the other way around. Try to gravity bleed for a few minutes per wheel to see if that fixes the problem.
    Feb 06 2014
    Ohio
    Found my problem. Right rear caliper is leaking from the piston. It's not a lot, but enough to start Running down the backing plate. So I still might order a set of braded lines since I have to open the system up.
    Nov 12 2013
    Middletown, CT
    Did you fix the issue ? I just bought a 2006 A3 with a very mushy brake pedal, I had to push it almost to the floor to stop the car, unnerving to say the least.
    When I get it home I'll pull the wheels and check for leaks....after that bleed the brakes, change pads if necessary etc.
    Any other suggestions ?
    Senior Member Three Rings 67Twisty's Avatar
    Jul 11 2015
    North Carolina
    Use Pentosin Dot 4 LV. It's the same as Audi OEM and Pep Boys carries it cheaper than dealer. 2006 on used low viscosity due to the design of the ABS. I also find I get a firmer brake pedal using the gravity bleed method. Standard rubber lines are fine unless you're racing it.
    Andy
    ‘17 Q7
    ‘07 Avant 6MTQ
    ‘03 525i Touring
