Results 1 to 4 of 4
    Deactivated Two Rings
    Aug 30 2013
    Help identifying a fault code?
    Hey all,
    I ran a scan on my A7 and saw an engine fault code:
    1 Fault Found:
    13272 - Catalyst System; Bank 1
    P0420 00 [096] - Efficiency Below Threshold
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 6
    Mileage: 98250 km
    Date: 2016.01.18
    Time: 14:46:51
    Readiness: 0000 0000
    Full scan:
    http://pastebin.com/1w3kFjJF
    Is this something I should get checked out? I should mention I do not have any mods other than a Roc-Euro intake.
    Thanks,
    Joel
    Veteran Member Three Rings jrsAudiA6's Avatar
    Oct 11 2011
    2018 A5 SB
    Riverside, California
    Quote Originally Posted by JKnetz View Post
    Hey all,
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 6
    Mileage: 98250 km
    Date: 2016.01.18
    Time: 14:46:51
    Full scan:
    Thanks,
    Joel
    I would take to the dealer and have them check it out. Since the issue is related to emissions it should be covered under the emission warranty.
    2018 A5 SB Matador Red Premium Plus
    2012 A6 Garnet Red, Prestige Pkg, Innovation Pkg, B&O, 20" Sport Pkg, H&R RSS + Coilover, Alcon Mono6/380mm front brakes, S6 rear rotors(356x22mm)/caliper carriers.
    034 DL fr suspension arms, 034 Track DL engine mounts, Eurocode Front and Rear sway bars & Alu Kreuz front brace, 034 ECU/TCU tune, DP PR 3.11, JHM Hx
    CTX 50% Tint F. S. Windows, CTX 30% Tint R. & R. S. Windows, 3M Pro PPF, hood, L & R fenders, AWE Exhaust w/o down pipes
    Oct 09 2013
    NC
    I'm getting the same fault code on my A6 (no mods). I get check engine light on for a day and then goes off by itself for awhile. Not sure what's going on yet. I haven't brought it to the dealer since I'm out of 50K miles warranty, but within emission warranty. Anybody know if O2 sensor is covered under 50K warranty or emission warranty?
    Oct 11 2011
    2018 A5 SB
    Quote Originally Posted by Culi View Post
    Check your emissions manual I believe it should have that info.
