Results 1 to 4 of 4
Thread: From AMB to AEB
    Junior Member Two Rings Jonnyth3boy's Avatar
    Feb 11 2016
    C7 S6; C5 RS6; B6 S4 Avant; B8 A4 Avant
    Lakewood, CO
    From AMB to AEB
    Ok, so here we go, I'm thinking of building my A4 B6 avant a little, nothing extravagant, maybe bigger injectors, MAF and a slightly bigger turbo, I'm still not sure. However if I want a safe block to "play with" it sounds like I need to either do a rod and piston upgrade on the AMB or use and AEB motor. My only question is, how much will I have to actually change over to the AEB block from my AMB block? I figure since I really only need the core block and maybe the head then most everything, like fuel rail, intake, throttle body and so forth I should just be able to switch, I don't see why I would have to change wiring either. Has anyone done this or have any info on it? Thanks in advance
    (Ideally I'd like to get my hands on a 24v VR6 for a monster build but I'm having a ton of trouble finding one, if anyone has one sitting around please PM me.) (also seeking 01E 6 speed transmission)
    Senior Member Two Rings shoemaker617's Avatar
    Nov 15 2011
    east coast
    Why not just build another AMB block?
    Sent from my SAMSUNG-SM-G900AZ using Tapatalk
    Feb 11 2016
    Lakewood, CO
    Cause I think it'd be cheaper to buy an AEB block instead of building a new AMB.
    Sent from my Nexus 5X using Audizine mobile app
    Registered Member One Ring The814Legend's Avatar
    Oct 18 2014
    '15 Jeep Cherokee Trailhawk, 94 F150 Flareside, '10 Harley XR1200, 08 Kawasaki KFX450R, '11 RZR900
    state college, PA
    Build your AMB and do an AEB head swap.
    then you can either swap everything to large port or port and polish your current setup
