Results 1 to 16 of 16
    Established Member Two Rings Schwebe's Avatar
    Dec 17 2015
    Kent Ohio
    APR Stage 2 on k03
    Hello everyone, I have been searching around a lot of threads and am very confused. I see other members talking about having APR stage 2 and 2+ on their stock k03s. I have also found YouTube videos of people having stage 2+ on stock turbo. I currently have stage 1+ with injectors, fmic, forge dv, full turbo back exhaust and intake. I want to go to stage 2+ to get the tune for my test pipe and fmic. I emailed APR and they told me they only do stage 2 with k04s.
    Am I missing something here?
    Senior Member Three Rings thetikm's Avatar
    Jun 24 2014
    NC
    I've always thought that a stage 2 or 2+ was the same as stage 1 or 1+, just with the check engine light written out.
    Veteran Member Four Rings krew53's Avatar
    2023 RS6 - 2013 B8.5 S4 - 2003 B6 1.8BT quattro
    Simi Valley, CA
    For APR.. Stage 1 and 1+ are for K03
    Stage 2 is K04
    Some tuning companies like unitronic have a stage 2 for K03.. So depending on what software you are looking at it may be different.
    2013 Solar Orange S4
    6MT | APR stage 2+ Ultra | Eurocode Headers | APR CPS | Meisterwerk clutch | Milltek Exhaust (resonated) | KW V3 coilovers | HRE FF01 | Stoptech trophy BBK | Alu Kreuz | Eurocode Sway / Endlinks / Trans & Dif mount | LYKT Control arms | E-Codes | Eurocode Short Shifter | P3 Gauge | Vinyl roof / trim / blades | B&O / JL Sound system | Probably more..
    Dec 17 2015
    Kent Ohio
    Well maybe it's time for a bit bigger turbo then!
    Aug 26 2005
    Quote Originally Posted by thetikm View Post
    That is illogical, since there is nothing to justify a higher stage designation number.
    Vorsprung durch Technik
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Their website used to reflect that, but now it only lists 1 and 1+.
    The '+' used to designate larger injectors, with the cat cel written out on the stage 2.
    2019 SQ5 Prestige
    Jun 27 2011
    Quote Originally Posted by texasboy21 View Post
    That's how it always has been. Stage 2 was just coded for test pipes and exhaust. The fact that it's now a k04 tune is news to me...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    APR Stage 2 has always been the tune with the K04. I had it when it came out many years ago. It was designated as Stage 2. There was no plus (+) as you had to go to the TT225 injectors with the turbo anyway.
    USP CLUB MEMBER #34
    Apr 01 2007
    houston texas
    Quote Originally Posted by CyberPMG View Post
    This isnt true. The k04 tune was always called "K04 tune". Stage 2 was their stock injector file with cat delete.
    Older threads will back this up:
    http://www.audizine.com/forum/showth...ge-1-to-2-1-8t
    2019 SQ5 Prestige
    Jun 27 2011
    APR Stage 2 on k03
    This. I'm pretty sure I haven't been reading the apr site wrong for 4+ years.
    Edit: since the internet doesn't forget:
    https://www.goapr.com/products/ecu_upgrade_8ea418t.html
    Stage two was a test pipe/HFC plus supporting mods tune. 2+ was that plus TT injectors.
    Their b7 offerings are aligned the same way. Stage 3 for the b7 doesn't officially exist but used to be a gtrs but now all they offer is a k04 (very different than a b6 k04, it's a pretty big upgrade).
    It sounds like APR is just revising/cutting back on offerings for older platforms. I don't blame them I can't imagine they sell many turbo upgrade kits for the b5/6/7 anymore.
    -CP
    2017 Q7 3.0t
    Dec 17 2015
    Kent Ohio
    That's why I was so confused when apr told me they only will do 1+ for me and that's it! I had read so many old threads that told a different story. That's okay though, I bought a 20 dollar k04 that needs rebuilt. Just need to find the best price to get it fixed! Any forum members do it?
    Feb 23 2004
    Stow, OH
    2013 is not old. I had APR's Stage 1+ tune done in 2005. First with a set of 550cc injectors that melted and caused backfires (Delphi brand), and then with the TT225 injectors. APR introduced the K04 tune in 2007 and called it Stage 2. I bought a new BW K04 and got one of APR's early Stage 2 programs. It was called Stage 2 back then. This was just with APR.
    Back then you only had limited choices:
    - Stage 1 (chip)
    - Stage 1+ (chip + injectors)
    - Stage 2 (K04 + injectors)
    - Stage 3 (GTRS turbo + injectors + MAF + manifold + TIP)
    That's all there was at that time.
    Since then, people stared introducing stages and pluses around Test Pipes/HFC/Deletes. The original stages were built to work with or without the stock exhaust and cat. They would just make a cat delete just an option on a Stage, but never call it something different.
    Now I believe other tuning companies never called the K04 a Stage 2 setup and this also has led to some of the confusion in stage meaning.
    USP CLUB MEMBER #34
    Jun 27 2011
    Did you see my link? Not that I've been around as long as some of you, but ever since I got my b6 in 2011 apr has had stage 2 be a test pipe and FMIC version of their stage 1 k03 tune.
    -CP
    2017 Q7 3.0t
    Apr 01 2007
    houston texas
    - Stage 1 (chip)
    How about a post from 2010 and 2011? The + is used to designate the larger injectors. Stg2 was stock injectors with a testpipe file.
    http://www.audizine.com/forum/showth...=1#post5060393
    http://www.audizine.com/forum/showth...=1#post6142723
    2019 SQ5 Prestige
    Feb 23 2004
    Stow, OH
    Not going to get into an argument over stage labels.
    To the OP: The only thing that they can tune is the cat delete for the K04 program (their website mentions the requirement of a high flow cat... the test pipe would be similar... and would code it out to not get any CEL). There's no software change for adding a FMIC or DSMIC.
    https://www.goapr.com/products/turbo_b6a4_k04.html
    The tuning that APR has for the K03 turbo (both basic chip and chip + injectors) assumes that the OEM cat is still in place with no option to code it out for a HFC or test pipe.
    USP CLUB MEMBER #34
    Jun 27 2011
    Haha nor is there any reason to. Let's just leave at: APR has changed their stage numbering scheme over the years. And it seems they've altered it again recently.
    In any event it's sort of academic, because while I liked my apr tune and have no complaints about it, there are better, cheaper options out there now that I would suggest over apr. especially since they're obviously paring back what they're offering for the 1.8t recently.
    -CP
    2017 Q7 3.0t
