Results 1 to 7 of 7
    Senior Member Two Rings Camelian's Avatar
    Aug 02 2010
    Tampa,fl
    Custom hardline B8 accuair e-level system
    This is a basically brand new full e-level custom setup for a b8 or 8.5. I do not daily drive this car. Only taken car out to car meets a few times and quick runs for lunch etc. Maybe 1500 miles total. Only reason for selling is the wife may be using this car so I will be parting out the mods.
    Lots of money and time was spent on this set up. The way it is the trunk, install goes in completely hidden where the spare tire goes and the OEM battery location stays. I had the mounds custom CnC made for a B8. They fit perfectly into the top hats and are very nice. The bags run on stock S4 shocks so you still have that sporty handling.
    Whats included:
    -Accuair e-level system with all wiring and touch pad
    -vu4 manifold
    -Viair 440cc compressor painted black
    -updated elevel sensors with B8 specific mounting hardware
    -2, 3 gallon seamless tanks (currently wrapped in matte metallic blue)
    -2 water traps with 45 degree npt
    -1/4"drain/fill lines and fittings to mount in bottom of wheel well (drain/fill from under car)
    -analog tank pressure gauge w/fittings
    -all hardlines with bulkheads (10 bulkhead fittings)
    -bunch of ptc tees, 90s etc
    -all 3/8" and 1/4" lines (with a bunch extra)
    -B8 trunk mount setup, with sand blasted plexiglass, two colors of LED strips, leather wrapped trim panel
    -custom bag setup with all CnC perchs/mounts etc.
    -Low mile S4 shocks
    -18" (IIRC) leader lines for fronts with bracket to mount to inside of wheel well
    I think that's it but I may be forgetting a few parts since there are so many of them. This will come with everything you need to install A custom air ride suspension into a B8 overnight. This will also go into a Q5 although I'm sure the trunk setup would need some slight modification and maybe the trim panel trimmed or re-flushed.
    I definitely have more than my asking price invested into this.
    Asking $5,000 obo
    Will ship, PayPal excepted as gift or add 3%, email questions.
    Thanks, Chris
    https://www.dropbox.com/s/0o8aift84y...%20pm.png?dl=0
    https://www.dropbox.com/s/racxdn0unj...%20pm.png?dl=0
    https://www.dropbox.com/s/jijf1t0myk...%20pm.png?dl=0
    2018 SQ5 Prestige, ECS x-pipe, 034 Stage 2 (current)
    2013 Allroad Prestige, Giac stg 2 e85, Accuair (sold)
    1985 VW cabby, white painted, red canvas top, 2nd owner, restoration project (current)
    03 A4 Avant 3.slow 6mt (sold, then reacquired, current )
    09 A4 Premium Plus, Nardo painted(sold)
    05 S4 b7 front(sold)
    02 Allroad 6mt, matte metallic red wrap (sold)
    02 A6 Avant, wrapped, 2.7t 6mt swapped(sold)
    99 A6 2.8 (ex took it lol)
    02 A4 1.8t (sold)
    Veteran Member Four Rings stereojorge's Avatar
    Oct 15 2013
    2014 Audi S4 P+ DSG, 2015 Audi SQ5 Prestige
    Tampa, Florida
    I know it just posted, but I have to give a bump and some creds to a genuine guy! Chris has modded my B8 S4 and knows his stuff real well. All of the work done in the pictures was done by his own hand and the equipment is fairly new as he barely drives his car as he has a daily for work. GLWS
    '14 Misano Red S4/APR Stage II+ DP ECU+TCU & UC/187mm Crank & AWE 57.55mm SC Pulleys/CMD Charge Chamber Intake/KW V1 Coilovers/EuroCode Sway Bars & AluKreuz/CR-15/034 Trans Mount/Apikol Rear Diff Mount/ECS Rear Diff Carrier Mounts/CMD Test Pipes/AWE Reso.Downpipes/AWE Track Exhaust 102mm Tips/Vossen HF-3 19" x 9.5"/Michelin PS4S'/StopTech Drilled Rotors/Akebono Euro Ceramic Pads/StopTech SS Lines
    Also: 2015 SQ5 Prestige | 2003 A4 Avant Quattro 6MT
    Previous: 2010 S4 P+ | 2008 A4 S-Line
    Veteran Member Four Rings Black_Pearl_B6's Avatar
    Aug 11 2010
    Agawam Ma
    That is one of the sickest setups I've seen
    09 Prestige Package
    Established Member Two Rings armnloaded's Avatar
    Sep 06 2015
    WhAt he said ^^ 🏽
    Established Member Two Rings Taudiz's Avatar
    Mar 28 2012
    2015 A3
    DENVER
    Pmd
    2015 SQ5 Sepang Blue/Black Nappa/High Gloss Black Pkg/B&O/carbon atlas/APR Carbino intake/22" Avant Garde/Bagged/Awe Exhaust
    Jul 17 2015
    2003 A4 1.8T Prem+ GONE
    New York
    Wish I could afford this right now. BUMP
    Nov 10 2012
    BURG VA
    Do you know if the trunk space in a b8 allroad is the same as the sedans? It looks the same in pics but never measured. I would love to pick this up for my allroad.
