    Veteran Member Four Rings jpulll's Avatar
    Jun 19 2014
    Ohio
    For those who broke their glovebox hinge
    what kind of tool did you use to break the slider pins free? did they glue the suckers in or something?
    so far I've been goin at it with special pliers and a hammer and well the slider pin is winning...technique I'm missing?
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    Some lube, and vise grips, and a hammer. Or just buy a slide hammer vise grip, or make one. http://m.instructables.com/id/How-To...-Slide-Hammer/
    Sent from my SM-G920P using Tapatalk
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Jun 19 2014
    Ohio
    Took the glovebox out. One side-side without piston-has a through hole so you can use a punch and hammer the slider pin out. One side done. Other side you have a decision- drill a hole and patch later or wrestle with it. I chose to drill a small hole big enough to get my punch in there. Other side done. 20 min of easy "wrestling".
    And then to make the piston like brand new again, I used the idea in one of the other threads to drill a small hole in the bottom, but that didnt solve the issue. My view is the piston should slide with equal force up and down. The reason the hinge broke in the first place is because it took so much force to move the piston that it caused the plastic to snap. So i opened the piston up and lubed it up with the PB silicone lube. Now its easy up and down motion. Now onto making some hinges.
    2003 A4 1.8T 5-spd Frankenturbo'd.
    Jun 14 2018
    BC
    How did the hinge repair go >???
    Got any pics
    Jan 24 2010
    Paramus,NJ USA
    needlenose vise grip.Move them back and forth as your pulling back.Should come out no problem.
    Ziddy Autowerks
