Results 1 to 8 of 8
Thread: Fuse blow
    Feb 07 2013
    New York
    Fuse blow
    Does anyone else have a problem with their cig lighter fuse when connecting a car charger? This is the second time I've plugged in my charger and the fuse blew. Please help
    Veteran Member Four Rings Sweep's Avatar
    Sep 05 2014
    Where are you connecting the car charger? Under the center armrest? I have not had any issues charging from there, however I am not using any of the higher amperage quick chargers
    Sent from my XT1575 using Tapatalk
    Ken
    2021 Q5e Prestige
    District Green
    2013 A5 Premium+ 6MT
    Glacier White | E-Codes | Bilstein | STaSIS | Roc-Euro | VMR V810 | Hankook | SunTek CXP
    Senior Member Three Rings d1amund's Avatar
    Oct 27 2014
    Park City, UT
    Fuse blow
    He said cig lighter so that means the ashtray area in front of the shifter.
    If you're blowing fuses two times I would suspect the charging device first. What is the model of charger? Have you tried using a new or different charger? Maybe the one you are using has a short...
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    I believe somewhere in the manual says you can only use the cigar lighter to charge for a short period of time, since it's not designed for charging. You'd better be using the 12v slot under the armrest.
    Oct 27 2014
    Park City, UT
    Fuse blow
    Very good point.
    If only Audi would get its shit together and just give us a USB port...like every other damn car!
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    Quote Originally Posted by d1amund View Post
    Very good point.
    They make a USB AMI cable that you can use in the glove box.
    2013 Audi S5 - EPL Stg 2 ECU/TCU
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
    Oct 27 2014
    Park City, UT
    Fuse blow
    Quote Originally Posted by HazeMyth View Post
    That thing is reactive, not proactive or current.
    I'm talking about a real USB port located within the center console/armrest area; something easily accessible to the driver. As opposed to using some adaptor for a socket that was all the rage back in the Great Depression.
    Sep 27 2015
    OH
    Where is the cig lighter fuse? 13 a5 premium and I checked the manual and it shows the fuse is in the rear passenger trunk location and that fuse seems to be good. Any input would be helpful, thanks
