Hello all, new member here.
So, for some time now I have been on the hunt for B6/B7 S4 with 6MT. I finally found a 2005 B6 six speed MT within reasonable proximity of my residence so I went to have a look and test drive.
Mileage - 82,000 mi
Cosmetically - Very good condition (per my standards)
Mechanically - Upon startup, had the notorious second of chain rattle. After that the motor seemed to idle fine. Motor was cold before start-up (ambient temperature was in the 50's). Took it for about a 30 minute test drive and all seemed well with regards to driveability (no weird engine sounds, no shaking with hwy speeds of 80 mph reached, brakes did not pulse). Coming back from the test drive the CEL did come on, the dealer connected the OBD scan tool right in front of me which read P2181 (Cooling System Performance). The dealer said that he would get this fixed which he said turned out to be some faulty hose. Not exactly sure about that...
Carfax (history) - Car has 4 previous owners, all maintenance stuff was done as scheduled until about 70,000 mi. The very last service record (engine checked) was performed at 77,579 mi on 01/14/2015 just over a year ago. So just for piece of mind, I decided to call the dealership that performed this "check engine" service to get some more details on what was actually done. Turns out the car was towed into the shop, because it didn't run at the time, due to jumped timing. The service mechanic at the dealerships said that the full timing service was recommended to the current owner. Well, apparently the car left that very dealership that day, via tow-truck, and that's the end of the service records!
So I am caught in this dilemma, the car now runs and pretty good for the most part, I just can't fathom pulling the trigger on this purchase now knowing the timing jump problem occurred.
Since the car is now in what appears to be good running condition, does that mean the timing stuff was fixed? The place that I am purchasing it from has no information on the history except for the Carfax.
Any help is greatly appreciated. Thanks in advance!
