    Established Member Two Rings Kardell's Avatar
    Sep 20 2015
    London a new Babylon
    AC compressor - Audi A4 B6 1.8T petrol 190
    Hi Everyone,
    I think I have to replace my AC compressor, I think a gas leak has been diagnosed.
    Do you know what is the part number for this model or disassembling is required to read the information from the compressor itself?
    If you have replaced it recently and know the details it would be very helpful.
    I am looking for AC compressor pump for Audi A4 B6 1.8T petrol 190 - registered in 2004
    The part number is I believe: 447220-9560
    Pumps with these numbers I have found on the Internet
    447220-9560 6SEU12C 04E04383 (A4 B6 CABRIOLET 2.4 3.0)
    447220-9560 8SEU12C 06E04559 (A4 B6 1.8T BFB ENGINE)
    I am not sure if there is any difference because of the engine size, but above it looks the same to me.
    Please advise.
    Best regards,
    Aug 26 2005
    There is no difference for the two engine sizes, but there can be a different mounting arrangement, using different mounting brackets.
    As is often the case, the ETKA shows different suffix letters per VIN.
    4 cylinder Petrol:
    8E0 260 805F a/c compressor
    F >> 8E-3-285 000*
    8E0 260 805AF a/c compressor
    F 8E-3-285 001>> 8E-4-237 000*
    8E0 260 805S a/c compressor
    8E0 260 805BJ a/c compressor
    F 8E-4-237 001>>*
    *4B0 260 810B pulley for a/c compressor to use for:
    8E0 260 805 F, 8E0 260 805 G, 8E0 260 805 S, 8E0 260 805 AF.
    *4F0 260 810G pulley for a/c compressor to use for:
    8E0 260 805 BJ
    ETKA does not describe the difference between PN suffixes if any.
    Vorsprung durch Technik
    Sep 20 2015
    Many thanks for your detailed input.
    My VIN is WUAZZZ8E24A185xxx if this can determine anything.
    Aug 26 2005
    Quote Originally Posted by Kardell View Post
    Your VIN is matched to the VIN ranges as 8E-4-185xxx for comparison to the ranges shown for the VIN splits. Therefore the compressor PNs applicable to your A4 are
    8E0 260 805 AF or 8E0 260 805 S
    Sep 20 2015
    Many thanks that was really helpful :)
