Results 1 to 17 of 17
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    Cool Facelift Headlights Removal (D3S Bulbs Installation Updated)
    I just got a couple of new HID bulbs to replace my slightly "yellowish" OEM bulbs (I got spoiled by the pure white led headlights of my buddy's m4). I googled but could not find any instruction for b8.5 headlights removal. All I got are for b8 cars, but they are a bit different.
    Can anyone please help me with this?
    Many Thanks!!!
    (I know it's silly to start a thread about this, but Ive tried my best, also emailed several websites that sell ecodes but got no reply)
    Updated:
    So I just installed those last night. The driver side bulb was relatively easy to install, no need to remove the headlight or any screws.
    Just open a rubber cap on the right , remove the stock bulb and install the new one.
    BUT, The passenger side headlights was a disaster...
    Without moving the headlight, I was only able to open the rubber cap, not even to remove the stock bulb.
    So I tried to take the headlight off.
    First I need to remove the center panel by popping up these screws (followed the instruction here on pg 4-5):
    http://uspmotorsports.com/downloads/...structions.pdf
    Then I removed these screws:
    And loosen these two screws (just loosen them, no need to remove), and unplug that big dirty oily cable as well:
    As a youtube video for b8 a5 suggests, now I can remove the headlight...
    ...NO! I don't know what they did for b8.5 headlights, it just didn't want to be removed! I pulled the headlight but I felt it was stuck on something underneath.
    After half an hour fighting with it, I gave up.
    However, I could pull the headlight a little bit out, which created some room between the filter box and the back of the headlight.
    I do have women's little heads so I could remove the oem bulb.
    Installing the new bulb was a hassle, in the first time of my life I wished my hands even smaller... Yeah, it took me another half an hour to insert the bulb into the headlight housing, and another half an hour to screw it (I mean twist it clockwise to tighten the bulb, sorry for my bad english) because at that angle it was extremely hard to apply force.
    And put everything back, that was it.
    Conclusion:
    1. You need to have small hands, very small ones, to install the bulbs without taking the headlights off, especially the passenger side one.
    2. Do NOT touch the bulb itself with your fingers, the oil on your fingers could ruin it. I used some white waitress gloves (made for women, of course).
    3. My bulb, Philips X-tremeVision, turned on side by side with the stock bulb, made almost no difference at first, except Philips bulb has a bit of greenish (not blue) hue around it, and if look carefully, a bit bright (id say 10%, not 50% as advertised), and a tiny little whiter (I doubt it was 4800k coz there was really a tiny difference).
    4. However, I am very satisfied with this result because after driving my car for an hour, the color of the headlights changes a little, becoming whiter. I saw somewhere saying it will become whiter and white after using and I can prove it's sort of true (coz I haven't driven it long enough to conclude). Now, when I get off the car and look at them they are almost perfect matches to the DRLs (a tiny bit warmer than DRLs).
    I tried to take a picture to show the difference right after the installation but there really was no difference what so ever on the phone display. So I didnt even bother keeping that picture.
    And this is the picture i took after an hour drive:
    (Looks nicer than what I see in my naked eyes though)
    From the picture it looks like the HID is whiter/bluer than the DRL but in naked eyes DRLs are just more like pure white than the HIDs.
    Current: '18 M3 ZCP
    Mods: | E85 | BMS Intake | MPE | BBS Fi-R | Brembo GT F+R BBK |
    Sold: '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL 179/57+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | ECS RS5 Front BBK | Macan Ducts | Brembo GT Rear BBK | AWE Touring | IE Intake | Bilstein B12 | USP Led kit | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    Account Terminated Four Rings
    Sep 13 2014
    New York
    Just remove torque screws holding them in. Reach in back and remove bulb. YouTube has some videos on Audi lights.
    Mar 21 2015
    It's only a couple of screws. There is a breather hose attached to the inside bottom of the housings that you need to pop of too. It's really easy.
    Senior Member Two Rings OptimusModulus's Avatar
    May 29 2014
    Chicago, IL
    Definitely post some before and after with the new white bulbs!
    Which ones did you get?
    2024 Ascari []RS6 Performance
    2021 Nardo []RS6 (Sold)
    2013 Ibis White []S5 6MT (Sold)
    “Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.” -- Jeremy Clarkson
    Oct 08 2015
    Thanks! I'll try tomorrow
    Oct 08 2015
    I got the Philips x-tremevision from hidconcept. They are rated 4800k and 50% brighter than stock. I'll surely post some pictures.
    - - - Updated - - -
    Quote Originally Posted by Jimmy ny View Post
    Are you saying that I don't need to remove the headlights?
    Oct 08 2015
    I saw those videos on youtube. But they only demonstrated the driver side lamps. I believe the passenger side is different because of the intake. Still need to know how to remove the passenger side headlight.
    Current: '18 M3 ZCP
    Mar 21 2015
    Quote Originally Posted by yjypm View Post
    They are the same headlight just reversed. You're really over thinking this. If you have to move something just move that item too. If it's the intake check out cts video on removing and adding the cai.
    Jul 05 2015
    West TX
    are our bulbs D3S?
    Mar 21 2015
    Quote Originally Posted by dux ducis View Post
    are our bulbs D3S?
    You bought bulbs and don't even know which ones you have? Yes they are D3S!
    Jul 05 2015
    West TX
    i didn't buy anything.....it was a question. wasn't sure if it differed between S4 and S5, and I want to make the right purchase without having to look under my hood.
    Mar 21 2015
    Huh. Your first post said you bought them. Oh well.
    Veteran Member Four Rings chrissurfr's Avatar
    Apr 26 2005
    Houston
    I have the same bulbs and love them. I hope you have small hands because it is a tight fit to swap them out.
    2017 Cement Grey TRD Pro 4runner
    2014 Suzuka Grey RS5 >:)
    • AWE Track Exhaust with center muffler straight piped
    • H&R Street Coilovers
    • BBS CH R - Gold with red caps
    • eCode headlights
    • Eventuri intake
    • JHM Stage 2 ECU/TCU
    • other things I forgot about
    Oct 08 2015
    Quote Originally Posted by chrissurfr View Post
    Just updated, such a hassle...
    Current: '18 M3 ZCP
    Oct 08 2015
    I knew they are just reversed I was just worrying about whether I would have enough room to do the install.
    And it actually caused me a lot of trouble during install... Maybe I missed a screw or two to remove, but ANYWAY I got it, hated the process, call me an idiot. XD
    Current: '18 M3 ZCP
    Jul 05 2015
    West TX
    what wattage was your bulb?
    Oct 08 2015
    They are 35 watts
    Listed here:
    http://www.hidconcept.com/d3s-philip...-hid-50-bulbs/
    Current: '18 M3 ZCP
