Results 1 to 7 of 7
    Oct 24 2015
    Perth, WA
    Guru review please? Any anomalies in the log charts below?
    Hi guys,
    I have had some codes lately, related to fuel, o2 sensors and EPC. After clearing them I only get the rear o2 sensor response error due to the HFC even though I have installed the spacer. The car drives nice still, with may be a bit of a roughish idle however I am leaning towards carbon build up which is one of my next jobs. In the meantime, can anyone spot issues with following charts from a log last night from about 50 minutes driving on city and highway.
    Thanks!!
    My respray thread
    Veteran Member Four Rings derrek's Avatar
    Jul 23 2010
    arizona
    Do you have the csv files?
    Edit: why did you take a 50 min log?
    Established Member Two Rings shahk62's Avatar
    Jul 14 2015
    Sydney
    Having the error with the space is still common unfortunately. The minicat is probably the best way to get rid of it. Otherwise using a tune to get rid of it
    2005.5 B7 A4 2.0T Quattro - 034 RSB + End links, GFB DV+, 034 Snub, 034 Billet Rear Diff Carrier Mounts, BSR CAI
    Veteran Member Three Rings allstock's Avatar
    Mar 19 2014
    greater sub of Chicago
    What did you use to get these values.
    Oct 24 2015
    Perth, WA
    I used VAGCOM and yes I so still have the CSV files. Just put them in excel to chart.
    Quote Originally Posted by shahk62 View Post
    When you say mini-cat do you mean something like the 034 one? That is what I have.
    Just another point, a lot of the last half of the curves are on cruise control at 60mph. Should the fuel rail fluctuate so much?
    My respray thread
    Jul 14 2015
    Sydney
    Quote Originally Posted by Okedokey View Post
    Something like that but sucks that you still have codes.
    It's actually really hard to say unless you were driving on a flat ground which the highways aren't.
    Oct 24 2015
    Perth, WA
    Down lane cove tunnel and say 20 min down m2. Pretty flat there for the most part. Wondering if there is a fuelling issue? There is no CEL, just a code, so I think its possibly the standard 02 rear code with the HFC. You can actually see the highway too and from sections on the blue MAF curve where it is reasonably flat. One good thing, my intake temp didn't go above 10oC delta so thats pretty good evidence of the CAI i think, however it would be good to see someone with a stock cai do the same.
    My respray thread
