The reality is that these are not track cars....not even remotely close. They are luxury rockets. Most of the big power gains from tuning are targeting at single acceleration runs and/or passing power type of gains.
To take a tightly packed TT V8 and tune it, then run it on a track will need myriad of other changes to be done reliably. This is a thermal nightmare. Something like the AMS cooling kit (they make this for the S6/7, not sure about the RS7) , a larger oil cooler, a larger oil pan, a lower temp thermostat (may require ECU changes), use of water wetter solution are the types of things you would need to help at the track. A properly designed vented hood wouldn't hurt either.
Plus, these car are still basically land yachts on any kind of track/twisty roads. Get a different car for tight and sporty driving.
