Results 1 to 11 of 11
Thread: Trim paint/wrap
    Established Member Two Rings vdubs97's Avatar
    Aug 23 2013
    2008 Audi A4 3.2 Quattro | 1987 Buick Grand National
    PA
    Trim paint/wrap
    Would like to have my window trim and grille trim either painted, plastidipped, or wrapped. Anyone have any experience with this? Trim is currently chrome and I would like to go to black. Lmk which method you guys think will work best and if someone has had it done and could give me a price quote that would b awesome. Thanks guys
    Instagram: kvnmcginty | 2008 Quartz Grey A4 3.2 Quattro | BC Racing Coilovers | VMR V705 wheels | Custom ECU tune by Eurodynamic | Custom Catless Downpipes by CBtuning | Custom Catback by CBtuning | Cupra R lip | Relaks FRP sideskirt blades | JOM ECS LED Tail Lights | H&R 10mm Spacers |
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    I think wrapping it would be best. I wouldn't dip it.
    Dec 02 2008
    Reading, PA
    I just ordered shadowline vinyl I'm going to have a crack at doing mine. I've done vinyl before but we'll see. Where in PA are you?
    Veteran Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    ^^ Shadowline is what I did too, is kind of a bitch if you're not experienced with vinyl.. But you'll get the hang of it. Just you'll probably want to buy an extra roll or so because trust me, you're gonna mess up haha.
    I did use a large sheet of 3m vinyl for my grille though, easier to work with than Shadowline but it comes in large sheets rather than rolls, so it's less useful for wrapping your trim with.
    2007 Porsche Cayman | 5MT
    Aug 23 2013
    PA
    Quote Originally Posted by KlineS147 View Post
    Located around Allentown Bethlehem area. I guess I'll look into shadowline too. I have no experience with wrapping vinyl tho.
    Veteran Member Three Rings DaveyDave424's Avatar
    Aug 02 2012
    LOS ANGELES
    I vote for vinyl wrapping. I did mine in Satin black and looks OEM
    Dec 02 2008
    Reading, PA
    Im in reading, ill get mine installed and then I can maybe help you through it.
    Aug 23 2013
    PA
    Awesome. Let me know
    Nov 26 2011
    2018 F80 M3 ZCP, 2007 RS4
    Just a tip: cut the shadowline vinyl into thin strips that are a bit wider than the trim. It makes it MUCH easier to apply and you get 3x the material to work with in case you mess up.
    Aug 23 2013
    PA
    Quote Originally Posted by AJacksA4 View Post
    Is it easy to bend and curve the shadowline with the trim above the windows on the side of the car or do u have to cut it in sections and seam it together?
    Oct 24 2015
    Perth, WA
    Use a heat gun, plenty of soapy water and stretch it where you want it to go.
    My respray thread
