    Senior Member Two Rings f4i-pilot's Avatar
    Feb 22 2016
    Hampton, VA
    Had a pretty decent night on starting my CVT to 5spd swap
    Gave up on my 03 Cabby's CVT after replacement of the TCM four months ago and now I have the clutch pack failure.
    Found a 03 donor 5spd down in Ga and drove last week to go get it.
    Got the transmission axels and pedals out of the donor tonight. Plan on taking on my CVT removal starting tomorrow night.
    Hopefully things go smoothly
    Veteran Member Three Rings Brens's Avatar
    Jan 07 2012
    B5 S4, MK1 TT 225, 3rd Gen Tacoma, 3rd Gen 4Runner
    Charleston, SC
    Very cool! Haven't seen any manual B6 cabs before (obv only came Auto) so this will be interesting. Did you buy that whole donor car? Are you parting it out afterwards ? If so, I could use some odds and ends pieces.
    -Brendan
    Brilliant Black B6 A4 Avant - 5spd 1.8T - Recaro - RNS-E - VMR - Daz - Woody Insides - Clutch/ Tune - Pink Coolant
    Feb 22 2016
    Hampton, VA
    Yes I have the donor car parts up now and will be selling the CVT trans, it has a brand new TCM, it was clutch pack failure and I just don't have time, money or patience to do it. Well technically I don't have the tools either
    Feb 22 2016
    Hampton, VA
    Slow going process with home life and problems with removing parts, at this point I have removed, complete center console, axels, oil lines, and pedals. Need to get the starter out, then cracking loose bolts for the CVT.
    Has anyone done this swap in a cabriolet yet, I have a few questions.
    Bentley manual has no info on CVT transmission removal, some I'm kinda playing it by ear at this point.
    Should I drop the main subframe?
    Should I keep my ECU and code it, or use the Manual ECU (immobilizer?¿)
    Jun 09 2016
    u.k
    I'm pretty sure that the auto's have larger injectors and a different map than the manuals, I'd swap the ECU and cluster from the manual to the auto car.
