Results 1 to 4 of 4
    Jun 16 2013
    SF, CA
    Do I need an AC evacuation/recharge?
    The other day I did my timing belt and a bunch of other work, and to make things easier I remove the whole frontend. I disconnected the front left and right AC hoses. Do I need to do anything to the AC system now?
    Thanks,
    John
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    You need a recharge. Next time if you do the timing belt on your car or others, try to take it to a shop rather than releasing that into the environment. Just assuming you did that that and not the "right way".
    You can recharge it yourself using a gram scale, a/c manifold gauge, and a vacuum pump, but a shop should be able to do it much quicker ~ 30 minutes for a proper vac and fill.
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Jun 16 2013
    SF, CA
    Thanks for letting me know. I didn't realize it was that harmful. I'll definitely do it right the next time.
    Feb 24 2004
    Minneapolis
    And now you really should do a new dryer now that you've opened it up. Moisture in the refrigerant turns into an acid, and your dryer is no doubt saturated.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
