Results 1 to 13 of 13
Thread: Oil leak help
    Junior Member Two Rings Nick-B7's Avatar
    May 01 2015
    Rhode Island
    Question Oil leak help
    Any idea where the leaks are coming from? Thank you
    Veteran Member Four Rings c@@kieMonsta's Avatar
    May 17 2009
    Idaho
    Nick, your pictures aren't showing up.
    Current:
    2019 Ford Expedition
    2009 3.0T A6 Avant w/Prestige package, Side Assist, and Cold Weather package
    2016 2.7 EcoBoost Ford F-150 XLT SCREW
    2007 3.2 A4 Deep Sea Blue Avant
    2006 A6 Arctic White Avant
    2002 1.8t A4 Sedan
    May 01 2015
    Rhode Island
    Images are taken from under the rear valve cover towards firewall.
    Veteran Member Four Rings PDX04a4's Avatar
    Jun 22 2008
    2006 A4 Avant S-line
    SL,UT
    Probably either the vacuum pump or valve cover gasket/cam girdle gasket
    Thanks for the EFF shack. -Dirty Mike and the Boyz
    May 01 2015
    Rhode Island
    I replaced the valve cover gasket recently but I was thinking vacuum pump also.
    Veteran Member Four Rings DanKing's Avatar
    Aug 14 2014
    California
    Quote Originally Posted by Nick-B7 View Post
    I have the same leak, vacuum pump. There around $200 :-( rub your finger under the vacuum pump . bet there is a little oil drip there.
    '07 6MT Brilliant Red 2.0T
    JHM Stage 1 • JHM test pipe • ST coilovers • Smoothed Cupra R lip • Relak Skirts • 3sdm 0.06 • 034 mounts • Revo snub • GFB DV+ • S4 Recaro seats • RS4 Steering Wheel • Joey'd Bi-Xenons • Phils V4 LEDs • STI projectors • LEDs everywhere • APR Carbonio Intake • p3cars Gauge
    May 01 2015
    Rhode Island
    Thanks DanKing. Yea I was reading that there were multiple revisions of the vacuum pump. Seems like a common problem for leaks.
    Aug 14 2014
    California
    Yeah, standard Audi life problems :(
    Senior Member Three Rings DrZEUS's Avatar
    Aug 18 2011
    B8.5 S4
    Mississauga
    Having oil leak problems as well. At first I thought it was coming from the oil filter housing (the leak is low). Had the housing reseated but no luck. Where is the vacuum pump located?
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by DrZEUS View Post
    by the back of the cylinder head. Its the part with the brake booster vacuum line is hooked up to.
    If you had just the seals replaced and still is leaking the housing itself mite need to be due to warpage issue's
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    I replaced just the o-ring on mine and its holding up fine. Just make sure you spray some silicone on it or use some oil before reinstalling or you may pinch it
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
    Aug 18 2011
    B8.5 S4
    Mississauga
    Quote Originally Posted by vce1232000 View Post
    For now, I have put an order in for an ECS aluminum oil filter housing to replace the stock plastic one. I hope this should fix it. My fear is if I have to replace the actual part of the housing that the canister screws into that is attached to the block. This can be expensive and laborious.
    Jun 17 2013
    jersey city nj
    Yes. I was referring to the whole oil filter "adapter" housing. Very rare the oil filter housing itself leaks oil unless someone has stripped it or double o ringed it by mistake
