Results 1 to 3 of 3
    Established Member Two Rings nitronutz's Avatar
    Jan 20 2016
    louisville
    cluster question
    Hi. I bought an used 04 s4 cluster to put into my 02 a4. I havent had a chance to install and adapt it yet. However I noticed the fuel gauge needle in the middle where i've seen the others for sale the needle is usually in the resting position. Does it mean the stepper on that needle might be bad? Or perhaps it was where the fuel level was when it was disassembled and should reset and function normally after I properly adapt it to my car?
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    Quote Originally Posted by nitronutz View Post
    While damage to the motor is always a possibility, it's highly unlikely and it was probably bumped during shipment. It will reset once you install/power it up. If not, it can be adjusted.
    Jan 20 2016
    louisville
    Ok thanks, fingers crossed lol.
