Results 1 to 8 of 8
    Veteran Member Three Rings b6a4's Avatar
    Oct 09 2006
    Asheville, NC
    Avant vs s4 avant
    Had a small fender bender that will require a new grill. Wanted to go s4. I keep hearing that the regular s4 grill will not fit. Something about it has to be an s-line.
    Will somebody set me straight. Does the s4 avant have a different hood?
    Which grill will fit my non s-line a4 avant? Liking for s4 grill not rs.
    Thanks! And I have searched.
    Stage 2 Banner Advertiser Four Rings
    Aug 07 2008
    Dallas, TX
    You can fit the S4 grille without issue. All A4, A4 S-Line and S4 grilles are the same size.
    However the genuine RS4 and Allroad grilles are all different shapes and only fit their respective models.
    Cheers,
    Alexander van Gerbig
    www.europrice.us
    [email protected]
    Veteran Member Four Rings avantagg's Avatar
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    I just swapped mine out for an S4 black optic. It's a direct fit as long as it's B8.
    2012 B8 Avant (3.0t Swapped)
    034 DP | APR UC | Ported Charger | Mertop Headers | Milltek Resonated Exhaust | Bilstein PSS-10 | Alu Kreuz | CR-15 | H&R Sways | 034 Inserts | Ecodes | A5 Cluster Swap | 3G+ MMI | RS4 FBSW | Black Headliner Swap | BUILD THREAD
    Oct 09 2006
    Asheville, NC
    Vendors?
    Aug 07 2008
    Dallas, TX
    If you have a B8 model you can see options here: A4, S4 B8 | '08-'12 Parts
    If you have a B8.5 model you can see options here: A4, S4, RS4, Allroad B8.5 | '13+ Parts
    Cheers,
    www.europrice.us
    [email protected]
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    Quote Originally Posted by avantagg View Post
    This looks great. This may be my next grille when something finally goes through my RS grill.
    My 2009 A4 Prem+ Build thread
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    I think black optics is a much better looking grille than the RS replicas. I cheated and dipped my stock grille black.
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Veteran Member Three Rings ToddBrunswick's Avatar
    Dec 07 2015
    PorscheCayenne
    Culver City, CA
    Quote Originally Posted by blbroo View Post
    I did the same.
    Pedal Responce Consigliere
    "I have a special practice. I handle one client" -Tom Hagen
