Results 1 to 19 of 19
    Veteran Member Three Rings rnagy86's Avatar
    Apr 12 2012
    RS4%2CRS6
    Budapest/Hungary
    RS4 B7 gearbox with LSD + axles + linkage to fit B5 and a one-piece propshaft!
    Hi guys
    I have an RS4 B7 gearbox set for sale with an LSD installed.
    I am also giving the axles and the linkage to fit perfectly to a B5.
    Would ship on a palette. Gearbox code is HLD. Perfect if you want to
    go fast quickly
    I am also including a one-piece propshaft with the kit.
    Also I must say that these items are practically new as they were only on
    the car for mapping on the dyno before it was converted to RWD.
    I will ship this to the US on a palette and the price is 2900 USD shipped
    to your door with TNT. (should take 1 week to get to the US)
    0MDac8Z_res.jpg12837191_1116801451692849_498587961_o.jpg12059969_1116801445026183_1271605639_o.jpg
    Veteran Member Three Rings gmdiluca's Avatar
    Mar 29 2013
    Ontario, Canada
    Cool!
    Dec 10 2013
    Borden, Ontario, Canada
    Is the one-piece made to fit the B5 chassis with the stock 01E? I'm interested in just the shaft.
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Apr 12 2012
    RS4%2CRS6
    Budapest/Hungary
    I want it to go as one. I am actually surprised that I still have this given the
    fact that a simple refurbished 01E transmission without an LSD is more expensive
    than this kit together.
    Apr 12 2012
    RS4%2CRS6
    Budapest/Hungary
    up :)
    Veteran Member Four Rings AudiForeman's Avatar
    Apr 24 2011
    B5A4T.06R1.B5S4
    co719/303
    What's the driveshaft made out of? Mileage on the trans, any rebuild ect? How much of s difference is the gearing vs a stock 01e?
    Boosted.Tuned.Cooled
    Apr 24 2011
    B5A4T.06R1.B5S4
    co719/303
    And a link to the build ?
    Apr 12 2012
    RS4%2CRS6
    Budapest/Hungary
    You can search for the gear ratios. The gearbox code is HLD. I sorry I don't have any pictures. The gearbox
    had 30k km when it was built and since then it only had two dyno sessions.
    Veteran Member Four Rings rockcandy's Avatar
    Sep 08 2009
    00 S4, 15 S4
    Phoenix, AZ
    What's the rwd setup? Sorry to thread jack a little
    Home of the slowest s4 of 2014
    I buy 2.7 engines. Either short/long blocks. Message me!
    Apr 12 2012
    RS4%2CRS6
    Budapest/Hungary
    Apr 24 2011
    B5A4T.06R1.B5S4
    co719/303
    When you say build, do you mean built to suit a b5? Or want the trams completely gone through and built with new guts?
    Apr 12 2012
    RS4%2CRS6
    Budapest/Hungary
    Quote Originally Posted by AudiForeman View Post
    What I mean is that it was disassembled and inspected but there was not much wear due to the low milage it has,
    so it was put back together with an LSD.
    Veteran Member Three Rings audi-hammer's Avatar
    Aug 28 2009
    Buffalo,NY
    This setup would be bad ass but I've read there is no way to make your speedometer work if you swap a b7 trans into a b5
    Silvia = 02 s4 stageIII
    Apr 12 2012
    RS4%2CRS6
    Budapest/Hungary
    Quote Originally Posted by audi-hammer View Post
    Well that's not true, you can re-use your ABS signal with a $80 module that you can easily find on the internet
    or do your own magnetic sensor and install it on the axle somewhere.
    Aug 28 2009
    Buffalo,NY
    Quote Originally Posted by rnagy86 View Post
    Good to know, when I tried to look into it no one had an answer yet. Awesome setup!
    Veteran Member Three Rings spd579's Avatar
    Jun 04 2012
    05 s2000, 2001 Mazda Miata with SR20deT(GT2871) swap, 1990 Mazda Miata(Tme attack(500whp))
    Charlotte, NC
    How does this work correctly with a B5 rear diff when the rear end ratios are different?
    Apr 12 2012
    RS4%2CRS6
    Budapest/Hungary
    Huh? The gearbox is 4.111.
    Apr 12 2012
    RS4%2CRS6
    Budapest/Hungary
    bump
    Apr 12 2012
    RS4%2CRS6
    Budapest/Hungary
    I am now providing gearbox mounts as well for B5 fitment to have a really drop-in kit,
    included in the original price.
