Results 1 to 16 of 16
Thread: Coil Pack help!
    Veteran Member Four Rings dennisA4's Avatar
    Jan 13 2006
    Houston
    Coil Pack help!
    Why is it every time I think I'm doing something quick and simple it turns into a major deal?
    This morning I wanted to check my spark plugs. So I did.
    And now I can't get 3 of the 4 coil packs to properly *click* into the harness.
    Luckily they are in enough that the car is driveable and no codes so I assume it's making an ok connection, but why won't they click in?!
    When removing them, I used a wide flathead screwdriver to pull on the clips (towards the passenger side of the car) until they clicked out.
    Any ideas???
    2014 A4 Prestige Quattro Tip
    Glacier White | S-Line Interior | Sport Package | Window Shades | 35% FormulaOne Tint | V1 Hardwired
    S4 Aluminum Pedals | 19x9.5 Avante Garde M590 | KW V1 Coilovers | AWE Dual Exhaust | ECS Luft-Technik Intake | Unitronic Stage 1+
    Veteran Member Three Rings Fastbke170's Avatar
    May 01 2015
    2003 Silver GSXR1000, Mazda 3S 2006
    Northport
    Quote Originally Posted by dennisA4 View Post
    Any ideas???
    Changed my Plugs a few months ago with a Mechanic friend of mine and had the same issue. He actually wound up plugging in all 4 packs to harness rack first then seating the packs down on to plugs. Going to change over soon to the R8 Packs Soon so I will be using this method. Good Luck !
    2012 A4 Moonlight Blue Metallic : Premium +: RS6 18" GUNMETAL WHEELS: AEM PRO DRY INTAKE: FRANKENTURBO F23L : TopGear UK HFC : TopGear UK 3"Stainless Steel Turbo Back Full Dual Exhaust: TopGear UK Eurodyne Custom Tune:Eurocode FMIC :3 Spoke S4 Black Steering Wheel w/DSG Paddle shifter : S-Tronic Shifter Knob w/Black Boot : LED White Interior: LED Red Footwell Conversion : Hoen White XEON Match Fog Bulbs :R8 Coil Packs: Puddle Projection Lamps with Audi Rings
    Jan 13 2006
    Houston
    Quote Originally Posted by Fastbke170 View Post
    ok, i kinda tried that real quick but will try again later.
    It's so weird because I've pushed and pushed and pushed and just can't seem to get it to catch.
    Very frustrating!
    BTW, all my plugs are still gapped at .028 and look like this... these still look ok?
    Senior Member Two Rings shayan_a4's Avatar
    Jul 12 2014
    2014 VW GTI and 2014 mercedes SL550 2014 b8.5 audi a4, c7 A6
    woodland hills
    thats how i did it lol
    Veteran Member Three Rings kt883's Avatar
    Nov 10 2010
    Stoney Creek
    just changed a buddies B7 and had the exact same problem, Turns out the tab on the harness was broken but still holding in place so it wouldn't lock and as soon as I looked at it I noticed it was cracked and hanging by a thread. He will need to repair the harness with a new connector
    May 31 2015
    Philadelphia, Pa
    I had the same issue, I actually though I was being a dumb a$@ not being able to remove the coil pack harness. On thing to mention, it was freezing and windy when I changed mine so the plastic clips were too brittle and hard to want to unclip. Also there is a bolt between the 1 and 2nd cylinder closest to the front of the car that you'll want to remove. And each cylinder have 2 small connectors behind the coil harness above the exhause manifold that can be disconnected to make it easier to move the harness assembally out the way. Be carefull with those little injectors because they bend easily.
    May 01 2015
    Northport
    Very frustrating!
    Honestly they look like they are burning Fine, I Changed mine at 35K and still have them here on my desk at work. OEM VAG Plugs, they are a bit more Tan then yours are. I have the New PFR7S8EG gapped at .032 and with a New Tune its running pretty sweet.
    Jan 13 2006
    Houston
    Quote Originally Posted by kt883 View Post
    Yeah, I've noticed a lot of these little clips are terribly brittle/easy to break.
    These in particular are wiggling around a little but I don't believe they are broken. Hope not anyway.
    Quote Originally Posted by Bruce G. View Post
    Ya, i got it all disconnected, its getting it back together that is the problem. ;)
    Jan 13 2006
    Houston
    Yep these are the exact same ones I have.
    But I had re-gapped them down to .028 because I'm a little modified. Should I have left them at .032?
    I'm getting some crazy bad gas mileage which is one reason I was checking on things.
    May 31 2015
    Philadelphia, Pa
    I didnt have an issue getting everything back together. Only one of my coils clicked when connected but I was confident that they all were secure. The annoying part is the harness's reluctance to move and be manipulated.
    May 01 2015
    Northport
    My Commute is about 76 Miles and I've Averaged as high as 35 and with all mods now 33 depending on traffic.
    I remember a day after I purchased the car I had a PO299 ( Low Boost) Code. Wound up being a Bad Turbo which was warrantied. My MPG sucked that week. Recently installed FMIC and while driving to work an Upper Intercooler Hose Blew off due to using the wrong style clamp. I was only a mile from work, No Code but just that short drive from Lugging Motor under No Boost Killed my Gas Milage obviously.
    Not Sure What your mileage on the car is but I would check intercooler Hoses, maybe your diverter valve is leaking?
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    I don't think you are supposed to pry the clips on the coils. I just pushed mine in and then they fully released.
    My 2009 A4 Prem+ Build thread
    Jan 13 2006
    Houston
    I remember a day after I purchased the car I had a PO299 ( Low Boost) Code. Wound up being a Bad Turbo which was warrantied. My MPG obviously sucked that week. Recently installed FMIC and while driving to work an Upper Intercooler Hose Blew off due to using the wrong style clamp. I was only a mile from work, No Code but just that short drive from Lugging Motor under No Boost Killed my Gas Milage obviously.
    That used to be my commute (total both ways) and I averaged 26 mpg. Now I'm only 6.5 miles from work on a 35mph road with 16 lights one direction (I get stopped at maybe half of them) and driving like grandma most of the time I get 17 mpg.
    My wife with a lead foot in her Volvo XC60 gets 22 mpg with almost the same kind of commute.
    Quote Originally Posted by Lambda13 View Post
    Sorry, I pulled back on the clips to REMOVE them. Now I'm just pushing and squeezing for all I'm worth trying to get those suckers to snap back together.
    Jul 07 2012
    Boston, MA
    No worries, but ya that's what I meant. I had to push mine in FURTHER to release the clip, then I was able to wiggle them out pretty effortlessly. Then when I pushed the harness back in they all popped in pretty easy.
    Jan 13 2006
    Houston
    Ah, gotcha!
    Well if I ever get these clipped back in, I'll try that next time.
    BTW, you said "full release".
    Nov 10 2010
    Stoney Creek
    These coil harnesses are poorly designed. The bmw e90 coil design is a much better design IMO. The coilpack has a swinging handle with latch which once lifted, swings around and spits the harness off the plug and can also be used as a grip with a hole for your finger. That latch locks the harness in place with an audible click when shut as well. If you do break the handle, you can replace that part in seconds for cheap.
