Originally Posted by
doug97gxe
So its not a piggyback its a full standalone .. i had a full standalone on my 350z ... HKS Fcon Vpro $3k .. it was wonderful .. it made the transition to boost over my previous piggyback UTEC $800 seamless .. it worked perfectly with the ECU .. but i had a constant CEL (could have been coded out) because some sensors couldn't be controlled by the Stand alone..
let me give you an idea of why you would buy an ABT vs lets say an ECU Tune...
First and foremost an ECU tune is going to be the safest and best bet 99.99999% of the time over a piggyback or full Standalone ... the ECU is the brain of the car.. you want the brain of your car to be aware of everything at all times and to control everything at all time.. something goes wrong.. the brain is what is controlling it and knows how to fix it at that very moment.. no delay .. no issues
Full Standalone is to take you beyond what your ECU can do... it will fine tune your car down to the perfect AF Ratio.. fuel curves .. ignition timing .. you ever see racers with laptops in their cars with crazy graphs and what not.. more than likely they are using a full stand alone..
once you go beyond stage 2 .. lets say custom turbo setup .. full built motor .. to the point where the ECU is no longer able to control boost or give you the perfect AF ratio.. then you go full standalone .. that's why this product is $4500 or if you want to custom tune your car yourself .. dyno and road tune.. nothing canned .. though i must say the canned tunes are very impressive for this platform
Its not a standalone. A standalone replaces the ECU. It receives the sensor data, provides the signal interpretation and gives commands directly. A piggyback acts as an intermediary and modifies the signal interpretation. This is a piggy back. A much more sophisticated one than CW, RC, JB1, etc but its a piggy like the MTM unit for the S4.
To the OP:
A sophisticated piggy like the one you are looking at can do some really great things BUT it can also have the similar drawbacks that both a piggy and a flash tune can have. Because it is CAN integrated and also can hijack more sensors you have a more complex set of interactions that are taking place and consequently much more added difficulty making things work correctly. The MTM piggy didnt provide significant gains on the US car that it was tried on...
http://www.audizine.com/forum/showth...omorrow/page24
Interestingly, Car and Drivers drive of it also was less than spectacular...
http://www.caranddriver.com/reviews/...briolet-review
Now that doesnt mean the units, when working correctly, won't perform every bit as well as the best tunes out there right now, but it does mean that there were certainly some teething issues that really havent been proven to be worked out yet.
The positive side is that if you can get this unit running correctly for our cars it may provide all the benefits of a flash tune but with the addition of never having touched the ECU code and also the possibility of not having jerkiness found in lower sophistication units like the CW that only hijack the map sensor. It certainly is a gamble though.
If it were me, i'd make sure they have a no questions asked return policy and be ready to do some logging, before/after dyno or 1/4 mile testing right when you get it to make sure it works well. Honestly i'd try the cheap piggy first though.
Mike
