Results 1 to 29 of 29
    Active Member Two Rings Audicoupej's Avatar
    Apr 15 2011
    Upstate, NY
    Carbon cleaning pics after walnut shell blasting
    While I was waiting for the suspension to be rebuilt I decided to do a carbon cleaning on the 2.0T. Car is at 80k miles. I'm not sure when/if it has been done before but I'm guessing it has.
    I used the BMW N54 adapter since I had it on hand from when I helped my friend clean his 335. It barely fits the ports but it works and helps keep the shells from going everywhere (they still go everywhere)
    Shop vac goes over round end. The blaster wand goes in the tiny hole and the large end goes into the intake ports.
    Media:
    I used all 25lbs I would buy extra if you've never done it before. You can always return it.
    Blaster:
    Now on to the fun pics
    I ran out of media since my local harbor freight only had one box of fine shells left. I used some brake clean and rags with picks to clean up the remainder after these pics. If I had more media that would have been unnecessary. The walnut blasting is one way out of several to clean the carbon. Unless you're planning on doing this a lot or have several cars to do I'm not sure if I would bother buying everything. I do think it's much faster and easier to blast it clean though.
    Has anyone readapted the intake manifold flap motor after cleaning? I'm guessing it's not needed but it seems like it might be a good idea.
    Jemmautodetailing.com
    Oct 24 2015
    Perth, WA
    Wow that works really well. would this be something you can hire?
    My respray thread
    Dec 18 2008
    Virginia
    i second the walnut blasting. I did it as well and it did great. Glad to know the BMW adapter works. I just used a bunch of drop cloths and my shopvac. stuff does get everywhere but it did a great job.
    Veteran Member Four Rings Avant4me's Avatar
    Aug 09 2011
    NOVA
    Quote Originally Posted by Audicoupej View Post
    everyone is walnut blasting these days time for me to get off my lazy butt and do the same.
    Nice work on yours though, did you tape anything off or cover your engine at all to control the spray?
    Glad to see you're still around John ;)
    ~2007 DTM A4 S-Line Avant, 6MT, Stasis cat back, RAI downpipe, JHM Stage2 93, JHM HPFP, HFC, APR snub mount, 034M SD Motor mounts, RS4 RSB, VMR 708 19x8.5 ET35 245/35/19, B5 perches, NEUSPEED sport springs ~
    Jan 02 2014
    LaSalle, Quebec, Canada
    Can you do it with a regular sand blasting gun? Like without the pressure tank?
    Veteran Member Three Rings DaveyDave424's Avatar
    Aug 02 2012
    LOS ANGELES
    I have had carbon cleaning done by my mechanic, but I know he didn't use this method with walnut shells and it still came out very clean. I believe they let it soak overnight, and continued to clean the next day.
    What's the advantage in doing this method, does it make the process faster, does it get more carbon out, etc ?
    Feb 16 2015
    Quote Originally Posted by Guig'z View Post
    I was able to do mine with great results using my 60 gallon compressor, and a pickup gun (I soda blasted mine due to its ability to simply dissolve)
    2005.5 Dolphin Grey A4 Avant 2.0T Tip / Premium / Lighting / Cold Weather / Sport
    RAI K0R-GT / JHM K04 Tune / 034 HFC -> B7 S4 CB/ ST Coilovers / Hyperco 8" 750 Lb / 034 RSB / 18Z / 15% Tint / S-Line Paddle MFSW / 034 St M and T Mounts / GEN II RNSE
    Feb 15 2016
    Cambridge,Ontario
    so outside of the setup equipment is there anything else needed to complete the job ?
    ie intake gaskets, orings that need to be replaced once you remove the intake etc ?
    what would make the job a thorough project as a "while you are in there" approach ?
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Oct 16 2008
    South Florida - Ft Lauderdale
    Yes walnut shells does work but I did both way and soda blast is much more efficient and quicker
    Phil
    Jan 02 2014
    Phil
    You used a pressure tank to?
    Or only a gun?
    Guess i'll try both!
    Oct 16 2008
    Or only a gun?
    I used a compressor
    Phil
    Veteran Member Four Rings jerseybrian's Avatar
    Jul 15 2011
    2008 Audi A4 2.0T Quattro QG 6spd
    Boynton Beach, FL
    I used a compressor
    Phil
    Sucks no one has made an Audi adapter head..
    REVO 2+ | VAST Meth | RAI HFC and 3" DP | Milltek S4 Exhaust | Autotech HPFP | 145bar PRV | JHM STS | BFI knob | 034 SD MM | ECS RA4 LWFW | ACT RS4 HDSS | QTP Cutout | Forge DV | APR Snub | Deval RS Front | Votexx 3pc wing | OEM Euro Bi-Xenons | Bilstein HD Shocks & ECS sleeves | Eibachs | RS4 RSB | S4 F&R Brakes | ECS S4 Slotted | Hawk HPS | ECS SS lines | FK LED Tails | CF Dipped Diffuser | Innovate LC1 | IE Billet | THULE | PODI
    Oct 16 2008
    Quote Originally Posted by jerseybrian View Post
    You don't need one with the soda blaster
    Here is my DIY
    http://www.audizine.com/forum/showth...ghlight=carbon
    Phil
    Dec 18 2008
    Virginia
    I tried to do the soda blasting per Fly, getting the Harbor Freight blaster. Unfortunately it didn't work too good for me and my compressor(Makita MAC5200 3hp/5gallon air compressor). I tested it out and it got clogged quickly (could have been the high August humidity and then a hose broke off the blaster soon after (couldn't repair it). I returned it and got the HF walnut blaster for like $30 and a box of shells. Did awesome and was quick. What I liked was the shells were easy to sweep up and any remainder, I just blew out into the yard. I read that you don't want baking soda to get on your plants but I think walnut shells are ok. I highly recommend it for guys with just your basic home air compressor
    Oct 24 2015
    Perth, WA
    Baking soda is just sodium bicarbonate which will raise the ph of anything for a short while, but will be diluted very quickly.
    My respray thread
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    I'd rather prefer to use sodium bicarbonate than walnut media, cause it looks like walnut media gets stuck in between the valve edges and the cylinder head near the mating surface. If i were to do this I'd just spray some solvent in the intake, let it sit there, and clean it out.
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Apr 15 2011
    Upstate, NY
    Quote Originally Posted by Okedokey View Post
    Mosy any shop should be able to do a carbon cleaning service for you. You would have to ask what method they use.
    Quote Originally Posted by mudd1011 View Post
    The adapter works but barely. If I was smart enough I'd try to prototype one for VAG cars. The kit BAVauto sells for the N54's has a drop cloth to cover the whole bay besides the intake valve area. I didn't bother as I just sucked up what I could after then once it was together I blew it out.
    Quote Originally Posted by Avant4me View Post
    I did use tape and clean rags to cover anything that was open (i.e. injectors, intake manifold, vacuum lines, dip stick hole, coolant lines, etc.)
    Thanks, this is Mark? I recognize the user name but cannot remember your name for certain.
    I'm sure you could as long as you have a compressor to blow the blasting media.
    Quote Originally Posted by DaveyDave424 View Post
    Clean is clean, I did this because I had access to the equipment so I only had to buy media. It's also easier than using chemicals and scraping.
    You should change the intake manifold gasket. Nothing else has to be changed. I did the cam follower because you remove the HPFP. If your intake manifold flap control motor is shot this also would make changing that very easy.
    Apr 15 2011
    Upstate, NY
    Quote Originally Posted by Denio24 View Post
    The few pieces you see that appear stuck in the pictures are easily removed by running a pick around the perimeter and then vacuuming out. It's no big deal really. What ever method works best for you. Cleaning them is the important part.
    Aug 09 2011
    NOVA
    Nope. Daniel...You don't know me from this screen name though.
    Mar 24 2013
    Oakdale, CT
    I managed to kill a large portion of my grass using my soda blaster. I now do all my blasting in the gravel driveway and not the yard.
    -Adam
    Oct 24 2015
    Perth, WA
    Yeah, its probably the hydrocarbons etc that killed it. Sodium bicarbonate is used in fish aquariums and other water systems to increase kH and pH. Its a weak base so watering it in would stop it killing grass. I would suggest though, avoidance is better ;)
    My respray thread
    Account Terminated Four Rings
    Oct 15 2013
    apparently if the valves are polished it helps to curb carbon build up on the valves. if so, a good port and polish of the heads should also reduce carbon buildup in the intake ducts.
    Apr 15 2011
    Upstate, NY
    Quote Originally Posted by esandes View Post
    It makes sense, a smoother surface should have less sticking to it.
    Feb 15 2016
    Cambridge,Ontario
    this has been big on the Porsche forums also and someone mentioned something that may help us. The guy who did it used a piece of rad hose it formed easily to fit just inside the port and hooked it right up to the vacuum, then drilled a hole in it for the cleaner nozzle. I thought it was quite innovative.
    1976 Yamaha XS 360
    Apr 15 2011
    Upstate, NY
    That's a great easy and cheap solution! Thanks for posting it.
    Jun 27 2011
    That's clever. Also one of those "why the hell hasn't anyone thought of that before" solutions.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Sep 11 2009
    A4 B7 2.0T MT, A4 B5 1.8 MT
    South Africa
    Do you have a picture or link to the thread?
    Apr 21 2017
    Syracuse, NY
    2.0T N54 Adapter fit
    Thanks for the post. What do you mean when you say the adapter barely fits? Wrong shape? Needs to be sanded down? Could be better with some layers of tape or something?
    Senior Member Two Rings BrianVan's Avatar
    Apr 03 2015
    Naperville, IL
    Search for Ford Prefect member. He has created a custom adapter. check out this thread
    http://www.audizine.com/forum/showth...me-w-92k-miles
    There is also a good you tube vid showing its usage from member Jroyalty7
    https://youtu.be/ffAQU2tckVs
