Originally Posted by
8520
Stuff.
You're right on all point except for kale!
However, finding S6 is hard, well one that doesn't cost an arm and a leg and it still leaves you with few items you must address:
- definitely junk the tip and put in 6MT, but that requires some good programming yoga on ECU
- above + 2.7t swap
Allroad is still by far cheaper and easier to bring to usable state. I reckon that running allroad with blow tip can be found very very easy for like 1k, not joking. From there:
1. Put in coilovers - 1k
2. Vinyl wrap flares and bumpers if you happen to get two tone. If you buy FBP allroad, that's non issue. - $250 in vinyl. But better to hunt FBP one down.
3. Since TIP is blown anyway, get rebuilt 01e from A6/S4 proper gearing and convert rear diff to 4.11. This will give you about 8% longer gears than S4/A6 have due to larger allroad tire diameter.
