Results 1 to 13 of 13
    Active Member Three Rings
    Feb 11 2015
    New Jersey
    DIY O2 Simulator for non-tuned cars running aftermarket downpipe and piggyback.
    So I started a different thread on being able to eliminate the CEL on vehicles running an aftermarket DP catted or not running a stock ECU tune.
    I am using the Area74 O2 simulator with an interrupt harness (MK7 extension harness for aftermarket DP with downstream cat) that will plug-in inline between the sensor and the car harness. This will be a direct plug and plug option for us. I have used every spacer configuration known to man with no luck. Some work for 3-wks others for 30-miles or more but still lend itself to a CEL.
    This plug and play device will take approx. 10-mins to install and uninstall, and best of all you can make it yourself!
    I will list the install pictures for you so you guys can repeat the process and then you can build your own.
    Feb 11 2015
    New Jersey
    Update the extension harness is on its way as well as the simulator. I will update with pics and harness after I have it all done.
    Sep 13 2015
    Hell City, Az.
    I believe you can just run emmanueles downpipe and fouler, and not get a code.
    His setup is proven to not throw a code even on decatted DPs.
    Feb 11 2015
    New Jersey
    not everyone has the DP and many others like to use one they prefer.
    This is for everyone else, I have the catted unitronic and nothing works hence why I am doing this setup for others
    Feb 11 2015
    New Jersey
    CEL on again after 5th spacer configuration, I should be getting the o2 simulator today and wiring so we will see what happens.
    Sep 13 2015
    Hell City, Az.
    then just use the fouler.. you don't need the downpipe.
    I was trying to state the fact that the fouler Emmanuele uses, seems to work to not get a code.
    Feb 11 2015
    New Jersey
    I have a fouler in the spacer, what is Emmanuelle using?
    Sep 13 2015
    Hell City, Az.
    To be honest, I don't want to speculate on brand or type, as I don't have enough knowledge on what he uses. It might be best to contact him directly.
    The "guarantee" is on the website itself..
    http://www.emmanueledesign.com/produ...ant=1201031205
    Feb 11 2015
    New Jersey
    3-weeks light back on with another spacer.
    The box should be in Monday
    Sep 29 2007
    02 S4 /07 S4 / 11 Q5 / 16 S3
    Clarkston, MI
    Quote Originally Posted by 2015S3 View Post
    Curious on how this goes, I m putting my cat less down pipe on in 2 weeks
    16 S3 with awe exhaust, usp downpipe, JB4
    2000 911 C2
    Sold 02 S4 with Apr stage 1 / millitek catback
    Sold-07 S4 with DTM kit, JHM tune, stasis exhaust, 19" VMR 710,
    Nov 19 2014
    California
    Running JB1, default map, 91 octane along with Bull X catted DP on my '16 S3 for ten days and I love it, but...
    I had installed the Bull X downpipe before I installed the JB1. With the DP only without spacer I got several CEL P0420. Then I installed Vibrant mid-size spacer provided by Emmanuele Design which eliminated the latter, but then it threw P013F (I believe it's lean to rich code). All these were happening after about 100 miles of driving.
    We then installed the JB1 and I drove a week and about 400 miles without any codes until last Friday when the check engine came back on with the same P013F. Thomas from Emmanuele recommended to install the larger spacer which I haven't tried yet.
    We reset the code and it hasn't come back yet and if it does, we'll install the larger spacer and I will report back on how it handles and if that doesn't work again, then I will try OP's solution, assuming he's going to install and let us know how it goes.
    Feb 11 2015
    New Jersey
    I have tried all the spacers no of them work for long term on the vibrant. I just received the unit today will be installing into the harness and update you all. As you will find the computer starts to learn the oscillation with the installed spacers/jets (vibrant) and if you change them up they will hold off for a few weeks then bang back on.
    The simulator constantly changes the oscillation of the wave that it puts out.
    Feb 11 2015
    New Jersey
    Installing tonight and will send the pics of the PNP harness and report back to all on results
