Results 1 to 22 of 22
Thread: Dirty!!!
    Veteran Member Three Rings gesTTalt's Avatar
    Oct 10 2004
    Dirty!!!
    Injectors that is. My car has about 96k on it. These injectors are filthy! Going to have the flow tested and cleaned @RC Engineering here in SoCal. Eager to see what they are flowing before and after clean.
    What supercharger?! lol
    07 Daytona Grey RS4
    Sep 21 2008
    new braunfels
    I'll be interested to see the results of the clean, FSi injectors don't normally suffer like traditional injectors do.
    Veteran Member Four Rings brad65ford's Avatar
    May 30 2005
    fl
    I so wanted to do the same when I did the CC still think mine are all running perfectly. keep us posted!
    Oct 10 2004
    Just got my injectors back. 4 were dripping with one very low. They were 26% difference between them before cleaning. Now, 1.1% with no issues.
    Eager to see how much of a difference it will be.
    07 Daytona Grey RS4
    Veteran Member Four Rings denis silva's Avatar
    Apr 14 2009
    2007 passat,subaru outback
    san mateo
    I think u gonna feel a big difference, and smoothness
    Sent from my iPhone using Tapatalklk
    Oct 10 2004
    Quote Originally Posted by denis silva View Post
    I know! I think there has been fueling issues for a while. I've basically changed out or cleaned my entire fuel system: replaced the LPFP, HPFP, fuel filter, now the fuel injectors, all the sensors have been changed, swapping out the fuel pressure relief valves too!
    07 Daytona Grey RS4
    Senior Member Two Rings SQ RS4's Avatar
    Feb 02 2015
    2008AudiRS4 2016AudiS6 2009NissanGTR 2016HondaPilot
    Clarksburg, MD
    Quote Originally Posted by gesTTalt View Post
    Does this mean you are keeping the RS4?
    Oct 10 2004
    Quote Originally Posted by SQ RS4 View Post
    Nope. I'm 99% sure it'll be going to another good owner.
    I just can't believe how much I've had to swap out.
    And there's that 1% chance that after I drive it again I'll change my mind lol
    07 Daytona Grey RS4
    Feb 13 2004
    AW E30 M3 & PB B7 RS4 (DD)
    The new lucky owner. I wish my PO did all that.
    Veteran Member Four Rings badbluers4's Avatar
    Oct 27 2011
    Atlanta, GA
    Wow I need to get my injectors cleaned.
    Jun 25 2009
    07 RS4, 91 BMW 318is
    SC
    Quote Originally Posted by badbluers4 View Post
    Yeah I would say any RS4 over 80k miles is a prime candidate for injector cleaning or replacement. Every person here and on AR that has had them flow tested and cleaned has shown significant delta in the injector flow pattern and/or flow rate of at least two injectors. I suspect a lot of difficult to diagnose driveability and performance problems people have had over the years on these cars can be attributed to poorly flowing injectors.
    Oct 11 2007
    Suburbia
    It's odd, mine at 89K had great flow numbers via VCDS, but I'm curious if I should have them pulled.....
    12' R8 Daytona/CF V10 6MT
    ~VF750 supercharged~Avior Ti non-res~GT coilovers~Girodiscs~Wingbacks~CF S-wheel~Maxton Aero bits~
    07' RS4 Daytona/Panda
    ~Jackal tune~Zinram 70mm DPs~JHM res catback~Custom CAI~Bilstein PSS9s~Girodiscs~JHM shifter~
    Jun 25 2009
    SC
    Quote Originally Posted by WinterRunner View Post
    It would be a good thing to do next time you're in for a carbon clean. No sense in doing unnecessary maintenance unless you have reason to suspect the injectors are causing problems.
    Veteran Member Four Rings Chuuey's Avatar
    Mar 06 2010
    E36
    Injectors are definitely on my list in the very near future. They do not show signs but I am sure they are in need of a good cleaning or replacement. I'm just debating on whether or not buying a new set vs. cleaning is the right route.
    1998 E36 M345 T | 2017 B9 Allroad | 2002 996 GT2
    Previous:
    2001.5 B5 S4 Avant
    2009 B8 S4 6MT
    2008 B7 RS4
    1991 200 20v Avant
    2010 997 C2
    1988 E28 535is Dinan Turbo (RIP)
    2019 B9 A4
    Oct 11 2007
    Suburbia
    No, of course not, the next CC would be when I do it, and considering I had one done about 9K miles ago, I'm not in any rush. Car runs like a top.
    For reference, my VCDS values on injector flow: Bank 1: -2.0%, -1.2% Bank 2: -1.4%, -2.0%
    Oct 10 2004
    I had good numbers too when logging. I was trying to run down some fueling issues and couldn't figure out what it was. Car still was strong, but not at what I expected based on the the AMD runs. With 80k at the install, the injectors had to be dirty. 4 of the 8 were dripping, with cyl 6 the lowest.
    As Komseh noted, getting them cleaned would be recommended, say at 80k or maybe even every other carbon clean. The process of removing injectors and sending to be cleaned wasn't bad. If people decide to go aftermarket injector, definitely get it flow matched with the rest. Heard of several horror stories.
    07 Daytona Grey RS4
    Oct 11 2007
    Suburbia
    I'd probably just buy 8 new ones @ $500, it's not a lot of coin. Are they flow matched when all new?
    Oct 27 2011
    Atlanta, GA
    Quote Originally Posted by komseh View Post
    Cool that's helpful thanks!
    Oct 10 2004
    You have to have them flow tested, particularly the aftermarket ones. Even though they are Hitachi, there can still be tolerance differences (at least from what I've read). $200 to flow test, plus $500 is much cheaper than $120-150 per injector.
    07 Daytona Grey RS4
    Oct 11 2007
    Suburbia
    Well this throws a wrench into my one stop shopping hopefulness. I assume most shops can't do this themselves? I can't believe new parts need to be flow tested, that just seems counter intuitive etc etc... Thanks for the info though
    Oct 10 2004
    I think if you got the stock injectors, you won't need to flow test. People have found variances in the hitachi one. An example of oem vs oem manufacturer difference was in my MAF. I bought an oem manufacturer part and made my car run like sh*t. Bought OEM, no issues. MAF is easy to swap, injectors would be a pain if one or more didn't meet specs.
    07 Daytona Grey RS4
    Oct 11 2007
    Suburbia
    Right, would def go OEM, I don't play like that unless proven otherwise.
