Results 1 to 3 of 3
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Audi's
    Branford, CT
    :: Excelerate Performance : Integrated Engineering: MK7/MQB Camber Plate Pre-order ::
    Excelerate Performance and Integrated Engineering Present
    Camber Plate Pre-Order Discounts!
    These camber plates must use the factory strut bearing and will fit the following applications:
    MK7 Golf| GTI | Golf R | MQB A3 | S3 | MK3 TT | MK3 TTS
    Features
    Adjustable up to -2 degrees of camber
    Direct replacement for OEM strut mounts
    CNC machined components for perfect fitment
    High quality, high strength spherical bearing
    Heat treated alloy steel bearing cup
    Uses OE thrust bearing for compatibility with nearly all aftermarket suspension
    Individually serialized to ensure quality and authenticity
    Lacking camber adjustability from the factory, MQB chassis cars are left begging for a solution to provide negative camber, which is necessary for maximum grip
    while cornering. Integrated Engineering adjustable camber plates allow camber adjustment up to -2 degrees, giving you the power to dial in your front suspension and shave
    down lap times. Along with added adjustability, IE camber plates feature a steel bearing, which removes the unwanted movement found in OEM rubber mounts and increases handling characteristics.
    Our engineering team looked at this application carefully in order to ensure optimum performance. Care was also taken to achieve
    desired adjustability without any detrimental effects to daily drivability. A heavy duty US-sourced Aurora spherical bearing controls the top of the shock absorber. It is secured in
    a high strength heat treated alloy steel cup, which has been designed to provide a lifetime of reliable service.
    The IE MQB camber plates have been designed to reuse the heavy-duty factory thrust bearing. In our testing, we have found this bearing to be well-suited
    for the job and reliable for thousands of miles. By using this bearing, our camber plates offer OEM fitment and allow nearly all aftermarket springs and coilovers to be used.
    Pre-Order Pricing and Quantity Details
    Retail Pricing - $499.99
    Quantities
    1-10 - 10% off - $449.99
    10+ - 15% off - $424.9
    9
    Payment details
    Non Refundable Desposits via Paypal or Credit Card by phone
    Paypal Address - [email protected]
    Phone -203-483-6100
    Flat Rate Shipping of $15 to anywhere in the Cont. US
    Canadian Orders please provide postal code in PM for quote.
    203-483-6100
    PRE-ORDER ENDS March 25 , 2016
    Deposits are due by 3/25/16.
    The balance is due by 4/1/16.
    Check Us Out on Social Media!
    Feb 14 2014
    Audi's
    Branford, CT
    A bunch of kits in stock now :)
    Feb 14 2014
    Audi's
    Branford, CT
    Thanks everyone for the support and pre-orders, didn't even hit the 10 mark, but that's okay. Expect us to run a sale soon for those who missed out.
    For everyone who placed a deposit should pay final invoice as we are packaging and planning to ship everything tomorrow 3/29/16. I will be sending reminders out to everyone tomorrow morning.
    Greg
