Excelerate Performance and Integrated Engineering Present
Features
Adjustable up to -2 degrees of camber
Direct replacement for OEM strut mounts
CNC machined components for perfect fitment
High quality, high strength spherical bearing
Heat treated alloy steel bearing cup
Uses OE thrust bearing for compatibility with nearly all aftermarket suspension
Individually serialized to ensure quality and authenticity
Lacking camber adjustability from the factory, MQB chassis cars are left begging for a solution to provide negative camber, which is necessary for maximum grip
while cornering. Integrated Engineering adjustable camber plates allow camber adjustment up to -2 degrees, giving you the power to dial in your front suspension and shave
down lap times. Along with added adjustability, IE camber plates feature a steel bearing, which removes the unwanted movement found in OEM rubber mounts and increases handling characteristics.
Our engineering team looked at this application carefully in order to ensure optimum performance. Care was also taken to achieve
desired adjustability without any detrimental effects to daily drivability. A heavy duty US-sourced Aurora spherical bearing controls the top of the shock absorber. It is secured in
a high strength heat treated alloy steel cup, which has been designed to provide a lifetime of reliable service.
The IE MQB camber plates have been designed to reuse the heavy-duty factory thrust bearing. In our testing, we have found this bearing to be well-suited
for the job and reliable for thousands of miles. By using this bearing, our camber plates offer OEM fitment and allow nearly all aftermarket springs and coilovers to be used.
Pre-Order Pricing and Quantity Details
Retail Pricing - $499.99
Quantities
1-10 - 10% off - $449.99
10+ - 15% off - $424.99
Payment details
Non Refundable Desposits via Paypal or Credit Card by phone
Paypal Address - [email protected]
Phone -203-483-6100
Flat Rate Shipping of $15 to anywhere in the Cont. US
Canadian Orders please provide postal code in PM for quote.
203-483-6100
PRE-ORDER ENDS March 25 , 2016
Deposits are due by 3/25/16.
The balance is due by 4/1/16.
Check Us Out on Social Media!
