In early B5 A4's(96-98.5), the air re-circulation option can be turned ON only if the AC compressor is ON. But in extreme cold weathers, AC compressor cannot be turned ON which in turn makes the air re-circulation option useless. But I read online that on facelift A4's we can press the ECON button and that will keep the air-recirculaation option ON even when the AC compressor is turned OFF. Can someone with facelift A4 confirm this?
Also, if I retrofit the face-lift climate control unit(center console swap) in my 98, will I also get the air re-circulation function when AC compressor not ON as in facelift A4's?
Or does it require a VAG com re-coding in ECM? I know the pins and connectors for pre-facelift and facelift HVAC units are identical so wondering what is the case..
