Results 1 to 8 of 8
    Senior Member Three Rings thetikm's Avatar
    Jun 24 2014
    NC
    Cylinder Head Questions
    My AMB cylinder head cracked on cylinder 2 at 145k. Was able to find an AEB head at my friends junkyard for $200. He was asking $350, but I had bought 2 AWM heads from him and they were both bad. Is there any steps I should do when I put the new head on? Like change the oil or anything to prelube the head? I also had just done a timing belt service within 3,000 miles of the head cracking, is there anyway to reuse any of the old parts?
    Dec 05 2007
    AEB intake manifold, amb cct, amb valve cover, and swap cam gears along with cam window. Plug necessary ports on intake manifold and I forget what is required for the fuel rail, if anything.
    May 24 2008
    cornish,me
    I had the same problem with my 2004 AMB head cracking. I found a good AWM head put in a new head gasket and timing components, then wrecked the car. I found a 2002 with a broken timing belt I used the head and timing components from the 2004 to repair the 2002. I've put about 1000 miles on it so far with no problems it runs great.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Don't use the AEB head. Too much work for you and you cannot retain SAI, meaning you will not pass emissions.
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Dec 05 2007
    Forgot about that one. The aeb head on the 06a block is not a direct swap. It is actually a modification.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    It is direct enough, but not bolt up by any means.
    OP is best off with any other small port head, as stated.
    2000 S4- Working?
    Jun 24 2014
    NC
    Thanks for the help guys. What about reusing timing components like the tensioner?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    If it only has 3k on it, go for it. I'd reuse everything.
    And when you put the hydraulic tensioner piston back in, go slowly like you would with a brake piston. I made the mistake of pulling the pin before I changed out the water pump when I did the job a couple weeks ago. I got really excited lol
    2000 S4- Working?
