Results 1 to 2 of 2
    Feb 29 2016
    Orlando, FL
    Wheel Fitment on 2011 TTS
    So, my peelers are peeling and time to get new shoes. Was looking at the Rohana RC7's, running stock 255/35/19 as they only have 3K miles on them and the question is which option?
    9.5 with ET 33 which equates to 13mm more clearance on the strut but 25mm shift to the outside (a bit much?) or
    9.5 with ET 50 which equates to 4mm LESS clearance on the strut but only 8mm shift to the outside or
    8.5 with ET 42 which equates to 16mm more clearance on the strut by and 5mm shift to the outside.
    So, what do you think would work best? Wasn't sure if there was 4mm to give up on the inside or not under compression/load. Would like to get the 9.5s on if possible but obviously don't want brake clearance or rubbing issues. Running a stock TTS with Magneto ride.
    Feb 29 2016
    Orlando, FL
    For those interest...the consensus is 8.5 ET 42 with the 255/35/19's. The 25MM shift on the 9.5/ET33 is a bit much, and the 9.5/ET50 will "probably not" clear of the brakes in front. So now I just got to sort out RC7 or MRR FS01 or Stance SF03...
